The Advanced SSH & Web Terminal is failing to start
it was working before and I can’t figure out what is wrong with init commands. Any suggest?
The Log:
s6-rc: info: service s6rc-oneshot-runner: starting
s6-rc: info: service s6rc-oneshot-runner successfully started
s6-rc: info: service base-addon-banner: starting
Add-on: Advanced SSH & Web Terminal
A supercharged SSH & Web Terminal access to your Home Assistant instance
Add-on version: 15.0.3
You are running the latest version of this add-on.
System: Home Assistant OS 10.3 (aarch64 / raspberrypi3-64)
Home Assistant Core: 2023.6.2
Home Assistant Supervisor: 2023.07.1
Please, share the above information when looking for help
or support in, e.g., GitHub, forums or the Discord chat.
s6-rc: info: service base-addon-banner successfully started
s6-rc: info: service fix-attrs: starting
s6-rc: info: service base-addon-log-level: starting
s6-rc: info: service fix-attrs successfully started
s6-rc: info: service base-addon-log-level successfully started
s6-rc: info: service legacy-cont-init: starting
s6-rc: info: service legacy-cont-init successfully started
s6-rc: info: service init-user: starting
s6-rc: info: service init-ssh: starting
s6-rc: info: service init-mysql: starting
s6-rc: info: service init-mosquitto: starting
s6-rc: info: service init-docker: starting
[09:55:35] INFO: Docker support has been enabled.
s6-rc: info: service init-docker successfully started
s6-rc: info: service init-mysql successfully started
[09:55:37] NOTICE: Session sharing has been disabled!
swapon: /backup/_swap.swap: Resource busy
[09:55:39] FATAL: Failed executing init command: if [ ! -f /backup/_swap.swap ]; then fallocate -l 2G /backup/_swap.swap {MESSAGE}{MESSAGE} mkswap /backup/_swap.swap {MESSAGE}{MESSAGE} chmod 0600 /backup/_swap.swap {MESSAGE}{MESSAGE} swapon /backup/_swap.swap {MESSAGE}{MESSAGE} echo SWAP_NEW_FILE_CREATED_USED ; elif [[ ! $(dmesg|grep _swap.swap) = *swap\ on* ]] ; then swapon /backup/_swap.swap {MESSAGE}{MESSAGE} echo SWAP_USING_OLD_FILE ; else swapoff /backup/_swap.swap {MESSAGE}{MESSAGE} swapon /backup/_swap.swap {MESSAGE}{MESSAGE} echo SWAP_FINAL_ELSE_STATEMENT ; fi
s6-rc: warning: unable to start service init-user: command exited 1
Thanks in advance!
