Advanced SSH & Web Terminal not working
I’m trying to install Advanced SSH & Web Terminaladd-on on my HA instance running on Raspberry Pi 4 B 8GB. Even after doing all the configurations as mentioned in the documentation, still the add-on does not start up correctly. I found the following in the log
s6-rc: info: service s6rc-oneshot-runner: starting
s6-rc: info: service s6rc-oneshot-runner successfully started
s6-rc: info: service base-addon-banner: starting
 Add-on: Advanced SSH & Web Terminal
 A supercharged SSH & Web Terminal access to your Home Assistant instance
 Add-on version: 15.0.7
 You are running the latest version of this add-on.
 System: Home Assistant OS 10.5  (aarch64 / raspberrypi4-64)
 Home Assistant Core: 2023.8.4
 Home Assistant Supervisor: 2023.08.1
 Please, share the above information when looking for help
 or support in, e.g., GitHub, forums or the Discord chat.
s6-rc: info: service base-addon-banner successfully started
s6-rc: info: service fix-attrs: starting
s6-rc: info: service base-addon-log-level: starting
s6-rc: info: service fix-attrs successfully started
s6-rc: info: service base-addon-log-level successfully started
s6-rc: info: service legacy-cont-init: starting
s6-rc: info: service legacy-cont-init successfully started
s6-rc: info: service init-user: starting
s6-rc: info: service init-ssh: starting
s6-rc: info: service init-mysql: starting
s6-rc: info: service init-mosquitto: starting
s6-rc: info: service init-docker: starting
s6-rc: info: service init-docker successfully started
s6-rc: info: service init-mysql successfully started
s6-rc: info: service init-mosquitto successfully started
fetch https://dl-cdn.alpinelinux.org/alpine/v3.18/main/aarch64/APKINDEX.tar.gz
[10:46:58] WARNING:
[10:46:58] WARNING: Logging in with a SSH password is security wise, a bad idea!
[10:46:58] WARNING: Please, consider using a public/private key pair.
[10:46:58] WARNING: What is this? https://kb.iu.edu/d/aews
[10:46:58] WARNING:
fetch https://dl-cdn.alpinelinux.org/alpine/v3.18/community/aarch64/APKINDEX.tar.gz
v3.18.3-126-g844291c27ba [https://dl-cdn.alpinelinux.org/alpine/v3.18/main]
v3.18.3-132-g8db57058edd [https://dl-cdn.alpinelinux.org/alpine/v3.18/community]
OK: 19943 distinct packages available
s6-rc: info: service init-ssh successfully started
ERROR: unable to select packages:
  - (no such package):
    required by: world[-]
[10:47:01] FATAL: Failed installing package -
s6-rc: warning: unable to start service init-user: command exited 1
/run/s6/basedir/scripts/rc.init: warning: s6-rc failed to properly bring all the services up! Check your logs (in /run/uncaught-logs/current if you have in-container logging) for more information.
/run/s6/basedir/scripts/rc.init: fatal: stopping the container.
s6-rc: info: service init-mysql: stopping
s6-rc: info: service init-mosquitto: stopping
s6-rc: info: service init-docker: stopping
s6-rc: info: service init-ssh: stopping
s6-rc: info: service init-mysql successfully stopped
s6-rc: info: service init-ssh successfully stopped
s6-rc: info: service init-mosquitto successfully stopped
s6-rc: info: service init-docker successfully stopped
s6-rc: info: service legacy-cont-init: stopping
s6-rc: info: service legacy-cont-init successfully stopped
s6-rc: info: service fix-attrs: stopping
s6-rc: info: service base-addon-log-level: stopping
s6-rc: info: service fix-attrs successfully stopped
s6-rc: info: service base-addon-log-level successfully stopped
s6-rc: info: service base-addon-banner: stopping
s6-rc: info: service base-addon-banner successfully stopped
s6-rc: info: service s6rc-oneshot-runner: stopping
s6-rc: info: service s6rc-oneshot-runner successfully stopped
Can anyone please help me rectify this?
Thank you in advance.
Anoma.
