Hi all,
Need some advice for a flow in Node red.
I want to achieve that a led strip beneath my tv cabinet goes ‘ON’ when the other light in the room go on and ‘OFF’ when the other lights in the room go off.
I have an automation for this in HA which worked perfectly, until it unexpectedly didn’t work anymore.
The ‘ON’ automation still works but the ‘OFF’ automation doesn’t work anymore and I can’t seem to find what causes this.
Now I’m trying to ‘rebuild’ this automation in Node Red, but can’t figure out which node to use for the trigger: ‘fourth button released after short press’ which used to trigger the action that put the led strip off.
This is the automation for the 'LED-strip ‘ON’:
And this is the automation for the 'LED-strip ‘OFF’:
I made this test-flow in Node Red:
with the same effect as the automation in HA: ‘ON’ works, but ‘OFF’ doesn’t work.
Could someone give me some advice on how to achieve a good flow with this?
I’m thinking the issue could be in the: ‘fourth button released after short press’-trigger which is configured in the HA-automation, but I can’t seem to find a suitable node for this.
