I am a total noob to home assistant, but I have got all my devices added and working by following tutorials etc. I recently went to add an Amazon Dash button and found that I ran into errors. I beleive that my python is out of date as I have run the following command and get that I have Python 2
pi@hassbian:~ $ python --version
Python 2.7.13
If I were to create a new build from the latest hassbian image would python be upgraded?
Also if I upgraded what directories and files do I need to copy over from my old installation to the new installation?
Would this keep my bluetooth and other addons I have installed or would I need to reinstall these?
For some reason python 2 is still the default on rasbian, so that is what you get when you just type python. python 3 is available as the python3 command, which is what you should be using for anything that doesn’t require python 2.
pi@hassbian:~
$ python
Python 2.7.13 (default, Nov 24 2017, 17:33:09)
[GCC 6.3.0 20170516] on linux2
Type "help", "copyright", "credits" or "license" for more information.
pi@hassbian:~
$ python3
Python 3.5.3 (default, Jan 19 2017, 14:11:04)
[GCC 6.3.0 20170124] on linux
KeyboardInterrupt
pi@hassbian:~
OK thank you for helping me to understand the versions installed, I have run both commands and have the following
Type “help”, “copyright”, “credits” or “license” for more information.
exit()
pi@hassbian:~ $ python3
I’ll go back to see how I fix my initial issue which gives me this error when installing a dash button
I think I found my issue and it is that the pyyaml files are not on the server, the folder is there but not the files. I’ve seen someone with similar issues and the answer was to manually install the requirements using;
Using sudo could be appropriate here, but it depends on how the package is going to be used.
If it is going to be used in a virtual environment, it is best installed by activating the virtual environment and installing it there with your original command. Indeed for some virtual environment setups, only packages installed in this way are available to the program.
I am afraid I know nothing of amazon dash, so I can’t help further without more information.
