I manage eufy_security custom integration which communicates with an add-on via web sockets. In short, two basic things happen;
integration might receive a message anytime
integration can send a command and expect a response for it.
For some reason, if the connection drops between integration and add-on, what is the best way to recover this? I am aware that, while initial setup of integration, we can use ConfigEnrtyNotReady exception which would force HA to retry it regularly to some extent.
But, in my example, initial setup is over and I am interested both recovering and informing the user properly afterwards.
Given your initilize method only runs at startup, you would have to catch the fact the webservice has disconnected in your update_local method and get it to reestablish the connection there. If you have managed to recover the connection then maybe a warning error in the logs, if not reestablished then an error level log. If it requires user intervention then you can raise a reauth exception which will show reauth required in the integrarion page. You could also raise a persistant notificarion but these can be annoying if it is only to inform.
Thanks for detailed description, inside update_local, if connection is not established, is there a mechanism to force integration into retrial mode as it was done at startup?
You can just create your reconnect code here. The configentrynotready exception basically retries loading the whole integration. As you have everyrhing loaded already but just lost connection to webservice, it makes more sense to just catch that and reconnect than reload.
Something like…
try:
await self._api.poll_refresh()
return self.data
except WebSocketConnectionException as exc:
try:
await self._api.connect()
return self.data
except CaptchaRequiredException as exc:
self.config.captcha_id = exc.captcha_id
self.config.captcha_img = exc.captcha_img
raise ConfigEntryAuthFailed() from exc
except MultiFactorCodeRequiredException as exc:
self.config.mfa_required = True
except (DriverNotConnectedException, WebSocketConnectionException) as exc:
raise UpdateFailed(f"Error communicating with Add-on: {exc}") from exc
If it just reconnects, I wouldn’t bother notifying and your integration has handled and carried on working. If it fails, I would raise an error in the logs, maybe an update status entity or a connected entity will help see there is an issue.
