Hi all,
I use node-red in a docker container (separate to my Home Assistant container), and all my automations are running as nod-red flows - no HA automations whatsoever.
I’ve just realised it’s been some time since I updated the nodes in my palette, and I’m currently running node-red-contrib-home-assistant-websocket version 0.30.1. So, I updated to the latest (v0.48.0) and it promptly clobbered all my automation flows with unknown nodes.
Clearly a lot has changed between then and now.
In terms of migrating, I was thinking my only option is:
- Spin up a new container
- Copy my existing config & flows
- Update my palette
- Manually fix/test each flow
- Either migrate back, or just leave running in new container and turn off old
Or is there a simpler way I’m not thinking about?
