FYI, some Zigbee router devices, Centralite, including those General Electrics, Iris, Ledvance / OSRAM / Sylvania, PEQ, Securify, SmartThings are known to not route Xiaomi/Aqara devices, and vice versa.
Better router results can be achieved by using IKEA, Nue/3A Home, (some OSRAM/Sylvania), XBee series 2 and 3, and CC2530 or CC2531 with router firmware.
Best tip on a simple Zigbee router device is again the often mentioned IKEA Trådfri Signal Repeater
Note! IKEA sells different “Tradfri Signal Repeater” models around the world to match local power-plug.
Another tip there is SONOFF BASIC ZBR3 as that has a CC2530 SoC/MCU with router firmware, but note BASICZBR3 runs a Zigbee Home Automation 1.2 stack so might not route all Zigbee 3.x devices.
And an additional tip is the SONOFF S31 Lite Zb which has the same type of CC2530 chip inside it
I have few a Xiaomi Aquara water sensors added through Zonoff Zigbee USB Stick (Not through Aquara Hub). Some of them which are far from the USB Stick become unresponsive. I bought two TRÅDFRI Signal repeaters and added them to the network. But the water sensors (Ones far from the USB Stick) are still offline. Do I have to do anything additional to increase the Zigbee range through these repeaters or just adding them to the network should work?
With Aqara devices, it is best to re-pair them with the router installed. Xiaomi Zigbee devices are known to stick to their original route, and for not changing by themselves.
Thanks. Apologies for a dumb question! How best should I repair? Do I just put the sensors in pairing mode or remove them first and repair again? How do I make sure sensors pick the repeater when pairing? Keep near the repeater than the zigbee stick when repairing?
I’m having trouble getting aqara sensors (motion and contact/door) paired up with Tradfri repeater bulbs. To begin with, all sensors were paired with a Conbee II stick, but I was experiencing some lag intermittently that I’d been unable to troubleshoot - and some of the sensors had yellow/red lines indicating low Link Quality Indicator (LQI).
So, because I had read the Tradfri bulbs worked well as repeaters, I bought 3 and placed them around the house. All three bulbs paired up with the Conbee II (and each other) right away.
What about the sensors? One random sensor automatically switched over from Conbee to one of the bulbs. But no matter what I do, I cannot get any of the other sensors paired with any of the repeater bulbs.
Here is what I have tried - what else can I do?
Deleted sensor from Phoscon app, repaired*. Result: Pairs back to Conbee
Deleted sensor from Phoscon app, unplugging Conbee for 10 mins, repaired*. Result: Pairs back to Conbee.
With sensor paired to Conbee, from Phoscon app I scanned for new light while pressing the pairing button repeatedly (6-10 times) on the sensor (read this method here). Result: No change, still paired to Conbee.
Left one sensor next to a lamp with a repeater bulb for a week . Result: No change.
**All repairing efforts attempted with sensor directly next to the repeater bulb (2 feet)
Thanks to the advice on this thread I bought two Ikea Tradfri repeaters to get a better signal from my Conbee II downstairs to two LED smart strips from Lidl connected upstairs more consistently. They were easy to setup with Phoscon, as @Mulperi says, use a paperclip to get them reset and then search for new lights in Phoscon. Thanks for the advice and help folks!
I have a long house and some of the Sonoff SNZB-02 Zigbee temperature sensors have lower signal strength because they are in the far corners of the house.
I just got a Sonoff S31 Lite Zigbee outlet, which has a TI CC2530 chip in it, and the ability to act as a repeater.
I have a Sonoff Zigbee Bridge (Tasmotized) and was able to easily pair the Sonoff S31 with it.
I put the S31 outlet closer to my farthest temp sensor than the others.
After reading about the Zigbee standard, I got the impression that Zigbee was a “automatic” mesh network. see reference:
Thus I was expecting that the far temp sensor (with the weaker signal) would automatically start using the S31 as a repeater, back to the ZB Bridge.
After waiting 2-3 hours, there is no evidence of repeating going on.
The ZHA-Map add-on is showing that all the ZB devices are still connecting back to the ZB Bridge.
Do I have to manually remove the far temp sensor from the Home Assistant Devices page, and then manually trigger a pairing of that far temp sensor with the S31, using the “Add Devices Via this Device” control?
I am now trying to manually add/pair my far temp sensor to the Sonoff S31.
First, I went into the HA Devices window and removed the far Sonoff temp sensor.
Then, I put the S31 in pairing mode by clicking on ADD DEVICES VIA THIS DEVICE and then pressed the pairing button on the temp sensor.
It appeared to start the pairing process, but failed to fully pair - no window opens to allow me to name it, and no new device in the HA Devices window.
I think I’m performing the pairing process correctly, but it’s not working.
It doesn’t make sense that a Sonoff ZB outlet won’t pair with a Sonoff ZB temp sensor!
Here’s a log:
Sent ‘mgmt_permit_joining_req’ to 00:12:4b:00:22:6a:7f:06: [<Status.SUCCESS: 0>]
[0xfde0:1:0x0006] ZCL deserialize: <ZCLHeader frame_control= manufacturer=None tsn=48 command_id=Command.Report_Attributes>
[0xfde0:1:0x0006] ZCL request 0x000a: [[Attribute(attrid=0, value=)]]
[0xfde0:1:0x0006] Attribute report received: on_off=0
[0x75b3:1:0x0405] ZCL deserialize: <ZCLHeader frame_control= manufacturer=None tsn=165 command_id=Command.Report_Attributes>
[0x75b3:1:0x0405] ZCL request 0x000a: [[Attribute(attrid=0, value=)]]
[0x75b3:1:0x0405] Attribute report received: measured_value=7320
Device 0x39f3 (00:12:4b:00:22:14:f5:59) joined the network
[0x39f3] Requesting ‘Node Descriptor’
Tries remaining: 2
[0x39f3] Extending timeout for 0xc1 request
Skip initialization for existing device 00:12:4b:00:22:14:f5:59
[0x75b3:1:0x0405] ZCL deserialize: <ZCLHeader frame_control= manufacturer=None tsn=166 command_id=Command.Report_Attributes>
[0x75b3:1:0x0405] Attribute report received: measured_value=7372
[0x39f3] Delivery error for seq # 0xc1, on endpoint id 0 cluster 0x0002: message send failure
Tries remaining: 1
[0x39f3] Extending timeout for 0xc3 request
[0x39f3] Delivery error for seq # 0xc3, on endpoint id 0 cluster 0x0002: message send failure
[0x39f3] Requesting Node Descriptor failed
[0x39f3] Discovering endpoints
Tries remaining: 3
[0x39f3] Extending timeout for 0xc5 request
[0x75b3:1:0x0402] ZCL deserialize: <ZCLHeader frame_control= manufacturer=None tsn=167 command_id=Command.Report_Attributes>
[0x75b3:1:0x0402] ZCL request 0x000a: [[Attribute(attrid=0, value=)]]
[0x75b3:1:0x0402] Attribute report received: measured_value=155
[0x39f3] Delivery error for seq # 0xc5, on endpoint id 0 cluster 0x0005: message send failure
Tries remaining: 2
[0x39f3] Extending timeout for 0xc7 request
There is only one coordinator device per zigbee network. The coordinator is the device that adds other devices, routers and end devices. I am still learning, but end devices that are battery powered often times will only be able to connect directly to the coordinator after they are added to the network. You could add any number of routers to the network and these end devices will still only look to connect directly to the coordinator. Hope I am wrong for your Sonoff end devices, but doubtful…
We know that line-powered Zigbee devices are supposed to perform a repeater function in the Zigbee network.
My original question, 2 posts back was essentially, How do I get the Sonoff S31 outlet to perform it’s repeater job?
In the absence of an answer to that, I’m left to just try stuff.
I went to the Home Assistant Config tab,
clicked on the Devices menu choice,
clicked on the S31 Lite ZB device (which was already paired with the Zigbee bridge),
clicked on ADD DEVICES VIA THIS DEVICE, and
pushed the pairing button on the Sonoff Temp sensor.
