Hello Community! I’m rather new to Home Assistant. I just got beyond the really basic Setups, like setting Triggers, Actions, Scenes, Basic Automation - via the Gui…
Now i think the Fun with smarter Automation can begin
But, before i start with my first ‘Project’, i wanted to ask you for the best approach, to avoid spending hours for the wrong (laborious, not proper scalable,…) way.
For skipping the description and bla, i tried to sum up the Questions down below
I’m used to the Basic concept of Programming in General (IfThenElse, Setting Variables,…), but definitly am no Programmer
Yet, i haven’t really understood/learned the Syntax of Yaml/Variables, even don’t know wether Graphic or Yaml editing would be better for me – but thats fine, gonna learn it by walking (and maybe later assistance if I get stuck :-)).
So, what is in my Mind:
I do have 6 Lights in the Hallway, Motion Sensors and Remotes (Tablet later)
Brightness and ColorTemp should be set according to the Daylight-Sensor
Remotes can be used to adjust Brightness, ColorTemp or switch to a different Scene.
Those Settings will be kept for a certain amount of Time, before the Standard-Automations kick in again. -
The Motion-Sensors kick in for 2 Minutes
If the Remotes / WebGui was used to turn on or alter Values, the Timeout for the Motion-Sensor should be set to 15 Minutes. The Timeout should be reset to 2 Mins after a given period of Time.
There are Priority-Conditions, that can always (partially) overrule the Settings from above (E.g. keep one Light Red while Bathroom occupied, while the others keep following the Automation.
Now, where and how should i setup which part?
Obviously, there are a lot of If-Then-Elses. Where should i collect them to keep it as logic, maintainable and scalable as possible?
Im struggeling with the “Collisions” of the different Conditions and Priorities (The needing to ignore the General Automation when Remote Used, and to (partially) ignore both when there is a Priority-Event, and to Fall back).
How should i approach my first Project without ending with tons of Scenes, Automations, each with tons of If-Then-Else?
What would you advice, where would you collect and update the Variables, when would you set device Settings via automations, when call a Scene?
How would you manage the different Levels of “Priority Settings”, which should sometimes only should affect single Devices, while the others keep following the “lower Prio” Automations?
Hope thats fine not to ask a specific ‘how’, but more a general experience-proven-approach. Those “why doesn’t that work” questions i’m willing, hopefully successfully, to google…
Would love to hear your advices!
