I am trying to setup the luminance settings in the configuration so that it will quickly detect light changes (even with low light) with a fast recovery time. I’m not sure what settings I need to change so that it will quickly display a luminance change; for example, when I turn my lights on and back off. Currently, it rarely changes. I tried changing the luminance recovery to 1 (from 10). That didn’t make any difference. I also changed the lower threshold for luminance to 1. That didn’t make any difference either.
I would appreciate someone shedding some light on this (pardon the pun).
Hi, I am trying to figure that one out as well … Are you using USB power or battery? I am assuming that the ZW100 on battery power and when sleeping only reports motion. The other sensors will only be reported when the ZW100 is awake. Can someone confirm?
I got this working very well after I made a couple of settings changes (per Aeon Labs support). The lux sensor now updates instantly even if there’s a 1 lux change. It’s the only multisensor I have that displays lux in real-time. Not even my Philips Hue motion sensor updates lux this granularly/quickly and with a large range.
However, when configured this way, it requires to be on USB. I think it’s because the battery would drain too quickly:
I haven’t upgraded to Z-Wave JS. So, not sure what the interface options/settings look like. If you can find where to change the configuration for the ZW100 Multisensor, below are the settings I changed. Be EXTREMELY careful to document what you changed, in case you need to put them back.
Below, are my notes for the specific changes I made:
Aeon Labs: (Configuration settings)
One Time: 240 (Default)
Changed to: 10
Command Options: Basic (Default)
Changed to: Binary Sensor Report
Report Only On Thresholds: Disabled (Default)
Changed to: Enabled
Parameter 48: Enable/disable to send a report on Threshold: 0 (Default)
Changed to: 64 (enable upper limit threshold for luminance)
