I have a problem corner of the basement, so I added a range extender. The extender added with no problem.
However, Home Assistant is marking the node dead as OpenZwave seems to be sending the extender a lot of requests that simply aren’t supported as it’s only an extender.
So my question is, since the unit is marked dead, will it still relay communication between nodes? Log below.
2019-10-19 13:03:13.447 Info, Node059, Sending (NoOp) message (Callback ID=0x26, Expected Reply=0x13) - NoOperation_Set (Node=59): 0x01, 0x09, 0x00, 0x13, 0x3b, 0x02, 0x00, 0x00, 0x25, 0x26, 0xdf
2019-10-19 13:03:13.456 Detail, Node059, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2019-10-19 13:03:13.456 Detail, Node059, ZW_SEND_DATA delivered to Z-Wave stack
2019-10-19 13:03:13.495 Detail, Node059, Received: 0x01, 0x07, 0x00, 0x13, 0x26, 0x00, 0x00, 0x05, 0xc8
2019-10-19 13:03:13.495 Detail, Node059, ZW_SEND_DATA Request with callback ID 0x26 received (expected 0x26)
2019-10-19 13:03:13.496 Info, Node059, Request RTT 48 Average Request RTT 48
2019-10-19 13:03:13.497 Detail, Node059, Removing current message
2019-10-19 13:03:13.497 Detail, Node059, Notification: Notification - NoOperation
2019-10-19 13:03:44.720 Detail, Node059, Queuing (Command) ControllerCommand_DeleteAllReturnRoutess (Node=59): 0x01, 0x05, 0x00, 0x47, 0x3b, 0x4a, 0xcc
2019-10-19 13:03:44.724 Info, Node059, Sending (Command) message (Callback ID=0x4a, Expected Reply=0x47) - ControllerCommand_DeleteAllReturnRoutess (Node=59): 0x01, 0x05, 0x00, 0x47, 0x3b, 0x4a, 0xcc
2019-10-19 13:03:44.732 Detail, Node059, Received: 0x01, 0x04, 0x01, 0x47, 0x01, 0xbc
2019-10-19 13:03:44.732 Info, Node059, Received reply to FUNC_ID_ZW_DELETE_RETURN_ROUTE - command in progress
2019-10-19 13:03:46.261 Detail, Node059, Received: 0x01, 0x05, 0x00, 0x47, 0x4a, 0x00, 0xf7
2019-10-19 13:03:46.268 Info, Node059, Received reply to FUNC_ID_ZW_DELETE_RETURN_ROUTE for node 59 - SUCCESS
2019-10-19 13:03:46.270 Detail, Node059, Removing current message
2019-10-19 13:03:46.275 Detail, Node059, Queuing (Command) ControllerCommand_AssignReturnRoute (Node=59): 0x01, 0x06, 0x00, 0x46, 0x3b, 0x01, 0x4b, 0xce
2019-10-19 13:03:46.280 Info, Node059, Sending (Command) message (Callback ID=0x4b, Expected Reply=0x46) - ControllerCommand_AssignReturnRoute (Node=59): 0x01, 0x06, 0x00, 0x46, 0x3b, 0x01, 0x4b, 0xce
2019-10-19 13:03:47.387 Detail, Node059, Received: 0x01, 0x04, 0x01, 0x46, 0x01, 0xbd
2019-10-19 13:03:47.389 Info, Node059, Received reply to FUNC_ID_ZW_ASSIGN_RETURN_ROUTE - command in progress
2019-10-19 13:03:48.705 Detail, Node059, Received: 0x01, 0x05, 0x00, 0x46, 0x4b, 0x00, 0xf7
2019-10-19 13:03:48.706 Info, Node059, Received reply to FUNC_ID_ZW_ASSIGN_RETURN_ROUTE for node 59 - SUCCESS
2019-10-19 13:03:48.708 Detail, Node059, Removing current message
2019-10-19 13:04:12.780 Detail, Node059, Query Stage Complete (CacheLoad)
2019-10-19 13:04:12.780 Detail, Node059, AdvanceQueries queryPending=0 queryRetries=0 queryStage=Associations live=1
2019-10-19 13:04:12.781 Detail, Node059, QueryStage_Associations
2019-10-19 13:04:12.781 Info, Node059, Number of association groups reported for node 59 is 1.
2019-10-19 13:04:12.781 Info, Node059, Get Associations for group 1 of node 59
2019-10-19 13:04:12.781 Detail, Node059, Queuing (Send) AssociationCmd_Get (Node=59): 0x01, 0x0a, 0x00, 0x13, 0x3b, 0x03, 0x85, 0x02, 0x01, 0x25, 0x6d, 0x10
2019-10-19 13:04:12.781 Detail, Node059, Queuing (Query) Query Stage Complete (Associations)
2019-10-19 13:04:12.781 Info, Node059, Sending (Send) message (Callback ID=0x6d, Expected Reply=0x04) - AssociationCmd_Get (Node=59): 0x01, 0x0a, 0x00, 0x13, 0x3b, 0x03, 0x85, 0x02, 0x01, 0x25, 0x6d, 0x10
2019-10-19 13:04:12.790 Detail, Node059, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2019-10-19 13:04:12.790 Detail, Node059, ZW_SEND_DATA delivered to Z-Wave stack
2019-10-19 13:04:22.782 Error, Node059, ERROR: Dropping command, expected response not received after 1 attempt(s)
2019-10-19 13:04:22.783 Detail, Node059, Removing current message
2019-10-19 13:04:22.783 Detail, Node059, Notification: Notification - TimeOut
2019-10-19 13:04:24.165 Detail, Node059, Query Stage Complete (Associations)
2019-10-19 13:04:24.165 Detail, Node059, AdvanceQueries queryPending=0 queryRetries=0 queryStage=Neighbors live=1
2019-10-19 13:04:24.165 Detail, Node059, QueryStage_Neighbors
2019-10-19 13:04:24.165 Detail, Node059, Queuing (Command) Get Routing Info (Node=59): 0x01, 0x07, 0x00, 0x80, 0x3b, 0x00, 0x00, 0x03, 0x40
2019-10-19 13:04:24.165 Detail, Node059, Queuing (Query) Query Stage Complete (Neighbors)
2019-10-19 13:04:24.166 Info, Node059, Sending (Command) message (Callback ID=0x00, Expected Reply=0x80) - Get Routing Info (Node=59): 0x01, 0x07, 0x00, 0x80, 0x3b, 0x00, 0x00, 0x03, 0x40
2019-10-19 13:04:24.170 Detail, Node059, Received: 0x01, 0x20, 0x01, 0x80, 0x84, 0x01, 0x38, 0x00, 0x16, 0x40, 0x08, 0x02, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xbf
2019-10-19 13:04:24.171 Info, Node059, Received reply to FUNC_ID_ZW_GET_ROUTING_INFO
2019-10-19 13:04:24.171 Info, Node059, Neighbors of this node are:
2019-10-19 13:04:24.171 Info, Node059, Node 3
2019-10-19 13:04:24.171 Info, Node059, Node 8
2019-10-19 13:04:24.171 Info, Node059, Node 9
2019-10-19 13:04:24.171 Info, Node059, Node 20
2019-10-19 13:04:24.171 Info, Node059, Node 21
2019-10-19 13:04:24.171 Info, Node059, Node 22
2019-10-19 13:04:24.171 Info, Node059, Node 34
2019-10-19 13:04:24.171 Info, Node059, Node 35
2019-10-19 13:04:24.171 Info, Node059, Node 37
2019-10-19 13:04:24.171 Info, Node059, Node 47
2019-10-19 13:04:24.172 Info, Node059, Node 52
2019-10-19 13:04:24.172 Info, Node059, Node 58
2019-10-19 13:04:24.172 Detail, Node059, Removing current message
2019-10-19 13:04:26.268 Detail, Node059, Query Stage Complete (Neighbors)
2019-10-19 13:04:26.268 Detail, Node059, AdvanceQueries queryPending=0 queryRetries=0 queryStage=Session live=1
2019-10-19 13:04:26.268 Detail, Node059, QueryStage_Session
2019-10-19 13:04:26.268 Detail, Node059, Queuing (Query) PowerlevelCmd_Get (Node=59): 0x01, 0x09, 0x00, 0x13, 0x3b, 0x02, 0x73, 0x02, 0x25, 0xa8, 0x20
2019-10-19 13:04:26.268 Detail, Node059, Queuing (Query) Query Stage Complete (Session)
2019-10-19 13:05:34.591 Info, Node059, Sending (Query) message (Callback ID=0xa8, Expected Reply=0x04) - PowerlevelCmd_Get (Node=59): 0x01, 0x09, 0x00, 0x13, 0x3b, 0x02, 0x73, 0x02, 0x25, 0xa8, 0x20
2019-10-19 13:05:35.606 Detail, Node059, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2019-10-19 13:05:35.606 Detail, Node059, ZW_SEND_DATA delivered to Z-Wave stack
2019-10-19 13:05:44.592 Error, Node059, ERROR: Dropping command, expected response not received after 1 attempt(s)
2019-10-19 13:05:44.592 Detail, Node059, Removing current message
2019-10-19 13:05:44.592 Detail, Node059, Notification: Notification - TimeOut
2019-10-19 13:05:44.598 Detail, Node059, Query Stage Complete (Session)
2019-10-19 13:05:44.598 Detail, Node059, AdvanceQueries queryPending=0 queryRetries=0 queryStage=Dynamic live=1
2019-10-19 13:05:44.598 Detail, Node059, QueryStage_Dynamic
2019-10-19 13:05:44.598 Info, Node059, BasicCmd_Get Not Supported on this node
2019-10-19 13:05:44.598 Detail, Node059, Queuing (Send) SwitchMultilevelCmd_Get (Node=59): 0x01, 0x09, 0x00, 0x13, 0x3b, 0x02, 0x26, 0x02, 0x25, 0xe1, 0x3c
2019-10-19 13:05:44.599 Detail, Node059, Queuing (Send) ColorCmd_Get (Node=59): 0x01, 0x0a, 0x00, 0x13, 0x3b, 0x03, 0x33, 0x03, 0x02, 0x25, 0xe2, 0x2b
2019-10-19 13:05:44.599 Detail, Node059, Queuing (Send) ColorCmd_Get (Node=59): 0x01, 0x0a, 0x00, 0x13, 0x3b, 0x03, 0x33, 0x03, 0x03, 0x25, 0xe3, 0x2b
2019-10-19 13:05:44.599 Detail, Node059, Queuing (Send) ColorCmd_Get (Node=59): 0x01, 0x0a, 0x00, 0x13, 0x3b, 0x03, 0x33, 0x03, 0x04, 0x25, 0xe4, 0x2b
2019-10-19 13:05:44.599 Detail, Node059, Queuing (Query) Query Stage Complete (Dynamic)
2019-10-19 13:05:44.600 Info, Node059, Sending (Send) message (Callback ID=0xe1, Expected Reply=0x04) - SwitchMultilevelCmd_Get (Node=59): 0x01, 0x09, 0x00, 0x13, 0x3b, 0x02, 0x26, 0x02, 0x25, 0xe1, 0x3c
2019-10-19 13:05:45.615 Detail, Node059, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2019-10-19 13:05:45.615 Detail, Node059, ZW_SEND_DATA delivered to Z-Wave stack
2019-10-19 13:05:45.645 Detail, Node059, Received: 0x01, 0x07, 0x00, 0x13, 0xe1, 0x01, 0x00, 0x68, 0x63
2019-10-19 13:05:45.645 Detail, Node059, ZW_SEND_DATA Request with callback ID 0xe1 received (expected 0xe1)
2019-10-19 13:05:45.645 Info, Node059, WARNING: ZW_SEND_DATA failed. No ACK received - device may be asleep.
2019-10-19 13:05:45.645 Warning, Node059, WARNING: Device is not a sleeping node.
2019-10-19 13:05:54.601 Error, Node059, ERROR: Dropping command, expected response not received after 1 attempt(s)
2019-10-19 13:05:54.601 Detail, Node059, Removing current message
2019-10-19 13:05:54.601 Detail, Node059, Notification: Notification - TimeOut
2019-10-19 13:05:54.612 Info, Node059, Sending (Send) message (Callback ID=0xe2, Expected Reply=0x04) - ColorCmd_Get (Node=59): 0x01, 0x0a, 0x00, 0x13, 0x3b, 0x03, 0x33, 0x03, 0x02, 0x25, 0xe2, 0x2b
2019-10-19 13:05:54.736 Detail, Node059, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2019-10-19 13:05:54.737 Detail, Node059, ZW_SEND_DATA delivered to Z-Wave stack
2019-10-19 13:05:58.387 Detail, Node059, Received: 0x01, 0x07, 0x00, 0x13, 0xe2, 0x01, 0x01, 0x79, 0x70
2019-10-19 13:05:58.387 Detail, Node059, ZW_SEND_DATA Request with callback ID 0xe2 received (expected 0xe2)
2019-10-19 13:05:58.387 Info, Node059, WARNING: ZW_SEND_DATA failed. No ACK received - device may be asleep.
2019-10-19 13:05:58.387 Warning, Node059, WARNING: Device is not a sleeping node.
2019-10-19 13:06:04.612 Error, Node059, ERROR: Dropping command, expected response not received after 1 attempt(s)
2019-10-19 13:06:04.613 Detail, Node059, Removing current message
2019-10-19 13:06:04.613 Detail, Node059, Notification: Notification - TimeOut
2019-10-19 13:06:04.624 Info, Node059, Sending (Send) message (Callback ID=0xe3, Expected Reply=0x04) - ColorCmd_Get (Node=59): 0x01, 0x0a, 0x00, 0x13, 0x3b, 0x03, 0x33, 0x03, 0x03, 0x25, 0xe3, 0x2b
2019-10-19 13:06:04.749 Detail, Node059, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2019-10-19 13:06:04.750 Detail, Node059, ZW_SEND_DATA delivered to Z-Wave stack
2019-10-19 13:06:08.497 Detail, Node059, Received: 0x01, 0x07, 0x00, 0x13, 0xe3, 0x01, 0x01, 0x83, 0x8b
2019-10-19 13:06:08.497 Detail, Node059, ZW_SEND_DATA Request with callback ID 0xe3 received (expected 0xe3)
2019-10-19 13:06:08.497 Info, Node059, WARNING: ZW_SEND_DATA failed. No ACK received - device may be asleep.
2019-10-19 13:06:08.498 Warning, Node059, WARNING: Device is not a sleeping node.
2019-10-19 13:06:08.498 Error, Node059, ERROR: node presumed dead
2019-10-19 13:06:08.498 Detail, Node059, Notification: Notification - Node Dead
2019-10-19 13:06:14.624 Error, Node059, ERROR: Dropping command because node is presumed dead
2019-10-19 13:06:14.624 Detail, Node059, Removing current message
2019-10-19 13:06:14.625 Detail, Node059, Notification: Notification - TimeOut
2019-10-19 13:06:14.635 Error, Node059, ERROR: Dropping command because node is presumed dead
2019-10-19 13:06:14.636 Detail, Node059, Removing current message
2019-10-19 13:06:39.200 Detail, Node059, Query Stage Complete (Dynamic)
2019-10-19 13:06:39.200 Detail, Node059, AdvanceQueries queryPending=0 queryRetries=0 queryStage=Configuration live=0
