First time poster here.
I have successfully configured Aeon Multisensor with binary reporting to switch on lights when there is movement, and also to switch off lights after 2 minutes of no movements.
However, sometimes the light fails to turn off. When I check the logs, the device is sometimes not reporting ‘Off’ state. I’ve set the config ‘3: On time’ to be 10 seconds so that it report no motion 10 seconds after if there is no motions.
Here is the recent logs on Node006 SensorBinary:
2017-10-11 21:03:23.317 Info, Node006, Received SensorBinary report: Sensor:59 State=On
2017-10-12 05:44:42.719 Info, Node006, Received SensorBinary report: Sensor:59 State=On
2017-10-12 05:44:57.662 Info, Node006, Received SensorBinary report: Sensor:196 State=Off
2017-10-12 06:00:36.306 Info, Node006, Received SensorBinary report: Sensor:59 State=On
2017-10-12 06:00:51.804 Info, Node006, Received SensorBinary report: Sensor:196 State=Off
2017-10-12 06:01:08.505 Info, Node006, Received SensorBinary report: Sensor:59 State=On
- As you can see at 21:03, there is an On state but not followed by Off state until the next day.
- So when I found my light was on in the morning, I triggered the motion sensor at 05:44.
- It reports Off 15 seconds later, then my light was turned off after 2 minutes. This works as it should!
- However at 06:01, again there is an On state but Off state is not reported.
The sensor is close to the controller and has a good connectivity. What could be the issue here?
Is there a workaround? What I’m thinking is since the ‘On’ state is very reliable, can I set an internal timer in hass to switch off the light and reset the timer if a motion is detected. That way it can also automatically turn off if I turn on the light using a switch (not a motion).
Thanks,
