but…
this is the second step: If I enter the Zwave config panel and click Start network a circling icon starts and never stops:
the stick keeps flashing, red, blue, yellow. Log says Driver failed…
I think I was able to add a device, taking the stick to a location, click it for include mode, and add the device was confirmed by a blue steady light for 2 seconds or so.
using it back, I see nothing changing in the HA interface, either the config panel, or the integration panel under Z-wave:
so, the stick is recognized, I even have a log and several other files in the /config and can include a device.
It is not displayed in the frontend and the stick keeps cycling the flashing colors…
what to do?
2019-11-29 21:42:43.017 Always, OpenZwave Version 1.4.3440 Starting Up
2019-11-29 21:43:06.708 Info, Setting Up Provided Network Key for Secure Communications
2019-11-29 21:43:06.709 Info, mgr, Added driver for controller /dev/ttyAMA0
2019-11-29 21:43:06.710 Info, Opening controller /dev/ttyAMA0
2019-11-29 21:43:06.710 Info, Trying to open serial port /dev/ttyAMA0 (attempt 1)
2019-11-29 21:43:06.710 Info, Serial port /dev/ttyAMA0 opened (attempt 1)
2019-11-29 21:43:06.710 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_GET_VERSION: 0x01, 0x03, 0x00, 0x15, 0xe9
2019-11-29 21:43:06.711 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_MEMORY_GET_ID: 0x01, 0x03, 0x00, 0x20, 0xdc
2019-11-29 21:43:06.711 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_GET_CONTROLLER_CAPABILITIES: 0x01, 0x03, 0x00, 0x05, 0xf9
2019-11-29 21:43:06.711 Detail, contrlr, Queuing (Command) FUNC_ID_SERIAL_API_GET_CAPABILITIES: 0x01, 0x03, 0x00, 0x07, 0xfb
2019-11-29 21:43:06.711 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_GET_SUC_NODE_ID: 0x01, 0x03, 0x00, 0x56, 0xaa
2019-11-29 21:43:06.711 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x15) - FUNC_ID_ZW_GET_VERSION: 0x01, 0x03, 0x00, 0x15, 0xe9
2019-11-29 21:43:06.711 Detail, contrlr, Notification: DriverFailed
