I have added a Nano Dimmer to my Z wave setup, and it works fine. I only have it connected to group S1 as my switch is only a single button momentary one. I would however like to be able to trigger a scene by double tapping or something like that. By consulting the manual I don’t seem to find that possibility with S1 . Does anyone know if that is possible?
Also interested in this. I read the Fibaro dimmer 2 module supports this through its ‘scene activation’ parameters. Maybe I should switch dimmers…
Did you have any luck with this? I added a second switch to S2 that will control the light but nothing shows up in Home Assistant entities list for S2?
I get a .light and a .switch for S1 Home Assistant entities?
No I unfortunately never got this solved. I actually the other day wanted to use S2 on those switches where I have that available to control other lights, but that doesn’t work. I don’t know if the wiring done to S2 might be wrong, but then the electrician has done it consistently throughout the house, since it doesn’t work anywhere.
It could be interesting to know if anyone has S2 on the Nano dimmer working?
Found this - https://www.vesternet.com/resources/application-notes/apnt-94/ - i will try in a couple of hours. It seems we need to configure group 4.
Really weird I tried to configure S2 with parameter 121 to the correct type of switch and now pressing S2 just turn on the light as S1 is doing. I can associate it with another light and in that case the light that the switch is wired to turn on and so does the associated one. I haven’t tried with a scene yet.
