Yep, I plan on dropping the reporting interval to 600s or more when I get this configured. The 10s was just for testing and I’ve already extended it out to 30s.
I’m still not getting reports on more reports still. When setting 62 (00111110
) I’m getting reports on outlets 2 and 3 only. I was expecting to get power consumption for outlets 1-5. I’m seeing the line 2018-02-02 16:38:51.913 Error, Node023, Cannot find endpoint map to instance for Command Class COMMAND_CLASS_METER endpoint 5
Setting 30 removes this message, setting 126 adds an additional error message but for endpoint 6.
Here’s my OZW log from when I set 62. Not sure what I’m missing, I’ll probably get around to some tests this weekend.
2018-02-02 16:38:42.423 Info, Node023, Value::Set - COMMAND_CLASS_CONFIGURATION - Report type sent in Reporting Group 1 - 101 - 1 - 62
2018-02-02 16:38:42.423 Info, Node023, Configuration::Set - Parameter=101, Value=62 Size=4
2018-02-02 16:38:42.423 Detail, Node023, Queuing (Send) ConfigurationCmd_Set (Node=23): 0x01, 0x0f, 0x00, 0x13, 0x17, 0x08, 0x70, 0x04, 0x65, 0x04, 0x00, 0x00, 0x00, 0x3e, 0x25, 0xa1, 0x53
2018-02-02 16:38:42.423 Detail, Node023, Queuing (Send) ConfigurationCmd_Get (Node=23): 0x01, 0x0a, 0x00, 0x13, 0x17, 0x03, 0x70, 0x05, 0x65, 0x25, 0xa2, 0x65
2018-02-02 16:38:42.423 Info, Node023, Sending (Send) message (Callback ID=0xa1, Expected Reply=0x13) - ConfigurationCmd_Set (Node=23): 0x01, 0x0f, 0x00, 0x13, 0x17, 0x08, 0x70, 0x04, 0x65, 0x04, 0x00, 0x00, 0x00, 0x3e, 0x25, 0xa1, 0x53
2018-02-02 16:38:42.433 Detail, Node023, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2018-02-02 16:38:42.433 Detail, Node023, ZW_SEND_DATA delivered to Z-Wave stack
2018-02-02 16:38:42.452 Detail, Node023, Received: 0x01, 0x07, 0x00, 0x13, 0xa1, 0x00, 0x00, 0x02, 0x48
2018-02-02 16:38:42.452 Detail, Node023, ZW_SEND_DATA Request with callback ID 0xa1 received (expected 0xa1)
2018-02-02 16:38:42.452 Info, Node023, Request RTT 29 Average Request RTT 28
2018-02-02 16:38:42.452 Detail, Node023, Removing current message
2018-02-02 16:38:42.452 Info, Node023, Sending (Send) message (Callback ID=0xa2, Expected Reply=0x04) - ConfigurationCmd_Get (Node=23): 0x01, 0x0a, 0x00, 0x13, 0x17, 0x03, 0x70, 0x05, 0x65, 0x25, 0xa2, 0x65
2018-02-02 16:38:42.461 Detail, Node023, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2018-02-02 16:38:42.461 Detail, Node023, ZW_SEND_DATA delivered to Z-Wave stack
2018-02-02 16:38:42.479 Detail, Node023, Received: 0x01, 0x07, 0x00, 0x13, 0xa2, 0x00, 0x00, 0x02, 0x4b
2018-02-02 16:38:42.479 Detail, Node023, ZW_SEND_DATA Request with callback ID 0xa2 received (expected 0xa2)
2018-02-02 16:38:42.479 Info, Node023, Request RTT 26 Average Request RTT 27
2018-02-02 16:38:42.490 Detail, Node023, Received: 0x01, 0x0e, 0x00, 0x04, 0x00, 0x17, 0x08, 0x70, 0x06, 0x65, 0x04, 0x00, 0x00, 0x00, 0x3e, 0xc3
2018-02-02 16:38:42.490 Info, Node023, Response RTT 37 Average Response RTT 38
2018-02-02 16:38:42.490 Detail, Node023, Initial read of value
2018-02-02 16:38:42.490 Info, Node023, Received Configuration report: Parameter=101, Value=62
2018-02-02 16:38:42.490 Detail, Node023, Expected reply and command class was received
2018-02-02 16:38:42.490 Detail, Node023, Message transaction complete
2018-02-02 16:38:42.490 Detail, Node023, Removing current message
2018-02-02 16:38:42.490 Detail, Node023, Notification: ValueChanged
2018-02-02 16:38:51.519 Detail, Node023, Received: 0x01, 0x18, 0x00, 0x04, 0x00, 0x17, 0x12, 0x60, 0x0d, 0x01, 0x00, 0x32, 0x02, 0x21, 0x64, 0x00, 0x00, 0x00, 0xb7, 0x00, 0x1e, 0x00, 0x00, 0x00, 0xb5, 0xe3
2018-02-02 16:38:51.519 Info, Node023, Received a MultiChannelEncap from node 23, endpoint 1 for Command Class COMMAND_CLASS_METER
2018-02-02 16:38:51.519 Detail, Node023, Refreshed Value: old value=false, new value=false, type=bool
2018-02-02 16:38:51.519 Detail, Node023, Changes to this value are not verified
2018-02-02 16:38:51.520 Info, Node023, Received Meter report from node 23: Energy=0.183kWh
2018-02-02 16:38:51.520 Detail, Node023, Refreshed Value: old value=0.181, new value=0.183, type=decimal
2018-02-02 16:38:51.520 Detail, Node023, Changes to this value are not verified
2018-02-02 16:38:51.520 Info, Node023, Previous value was 0.181kWh, received 30 seconds ago.
2018-02-02 16:38:51.520 Detail, Node023, Refreshed Value: old value=0.181, new value=0.181, type=decimal
2018-02-02 16:38:51.520 Detail, Node023, Refreshed Value: old value=30, new value=30, type=int
2018-02-02 16:38:51.520 Detail, Node023, Notification: ValueChanged
2018-02-02 16:38:51.524 Detail, Node023, Notification: ValueChanged
2018-02-02 16:38:51.528 Detail, Node023, Notification: ValueChanged
2018-02-02 16:38:51.531 Detail, Node023, Notification: ValueChanged
2018-02-02 16:38:51.605 Detail, Node023, Received: 0x01, 0x18, 0x00, 0x04, 0x00, 0x17, 0x12, 0x60, 0x0d, 0x02, 0x00, 0x32, 0x02, 0x21, 0x64, 0x00, 0x00, 0x00, 0x00, 0x00, 0x1e, 0x00, 0x00, 0x00, 0x00, 0xe2
2018-02-02 16:38:51.605 Info, Node023, Received a MultiChannelEncap from node 23, endpoint 2 for Command Class COMMAND_CLASS_METER
2018-02-02 16:38:51.605 Detail, Node023, Refreshed Value: old value=false, new value=false, type=bool
2018-02-02 16:38:51.605 Detail, Node023, Changes to this value are not verified
2018-02-02 16:38:51.605 Info, Node023, Received Meter report from node 23: Energy=0.000kWh
2018-02-02 16:38:51.605 Detail, Node023, Refreshed Value: old value=0.000, new value=0.000, type=decimal
2018-02-02 16:38:51.606 Detail, Node023, Changes to this value are not verified
2018-02-02 16:38:51.606 Info, Node023, Previous value was 0.000kWh, received 30 seconds ago.
2018-02-02 16:38:51.606 Detail, Node023, Refreshed Value: old value=0.000, new value=0.000, type=decimal
2018-02-02 16:38:51.606 Detail, Node023, Refreshed Value: old value=30, new value=30, type=int
2018-02-02 16:38:51.606 Detail, Node023, Notification: ValueChanged
2018-02-02 16:38:51.609 Detail, Node023, Notification: ValueChanged
2018-02-02 16:38:51.613 Detail, Node023, Notification: ValueChanged
2018-02-02 16:38:51.616 Detail, Node023, Notification: ValueChanged
2018-02-02 16:38:51.705 Detail, Node023, Received: 0x01, 0x18, 0x00, 0x04, 0x00, 0x17, 0x12, 0x60, 0x0d, 0x03, 0x00, 0x32, 0x02, 0x21, 0x64, 0x00, 0x00, 0x00, 0x0a, 0x00, 0x1e, 0x00, 0x00, 0x00, 0x09, 0xe0
2018-02-02 16:38:51.705 Info, Node023, Received a MultiChannelEncap from node 23, endpoint 3 for Command Class COMMAND_CLASS_METER
2018-02-02 16:38:51.705 Detail, Node023, Refreshed Value: old value=false, new value=false, type=bool
2018-02-02 16:38:51.705 Detail, Node023, Changes to this value are not verified
2018-02-02 16:38:51.705 Info, Node023, Received Meter report from node 23: Energy=0.010kWh
2018-02-02 16:38:51.705 Detail, Node023, Refreshed Value: old value=0.009, new value=0.010, type=decimal
2018-02-02 16:38:51.706 Info, Node023, Previous value was 0.009kWh, received 30 seconds ago.
2018-02-02 16:38:51.706 Detail, Node023, Refreshed Value: old value=0.009, new value=0.009, type=decimal
2018-02-02 16:38:51.706 Detail, Node023, Changes to this value are not verified
2018-02-02 16:38:51.706 Detail, Node023, Refreshed Value: old value=30, new value=30, type=int
2018-02-02 16:38:51.706 Detail, Node023, Notification: ValueChanged
2018-02-02 16:38:51.708 Detail, Node023, Notification: ValueChanged
2018-02-02 16:38:51.711 Detail, Node023, Notification: ValueChanged
2018-02-02 16:38:51.713 Detail, Node023, Notification: ValueChanged
2018-02-02 16:38:51.805 Detail, Node023, Received: 0x01, 0x18, 0x00, 0x04, 0x00, 0x17, 0x12, 0x60, 0x0d, 0x04, 0x00, 0x32, 0x02, 0x21, 0x64, 0x00, 0x00, 0x00, 0x08, 0x0d, 0xe4, 0x00, 0x00, 0x00, 0x04, 0x1f
2018-02-02 16:38:51.805 Info, Node023, Received a MultiChannelEncap from node 23, endpoint 4 for Command Class COMMAND_CLASS_METER
2018-02-02 16:38:51.805 Detail, Node023, Refreshed Value: old value=false, new value=false, type=bool
2018-02-02 16:38:51.805 Detail, Node023, Changes to this value are not verified
2018-02-02 16:38:51.805 Info, Node023, Received Meter report from node 23: Energy=0.008kWh
2018-02-02 16:38:51.805 Detail, Node023, Refreshed Value: old value=0.004, new value=0.008, type=decimal
2018-02-02 16:38:51.805 Info, Node023, Previous value was 0.004kWh, received 3556 seconds ago.
2018-02-02 16:38:51.806 Detail, Node023, Refreshed Value: old value=0.003, new value=0.004, type=decimal
2018-02-02 16:38:51.806 Detail, Node023, Changes to this value are not verified
2018-02-02 16:38:51.806 Detail, Node023, Refreshed Value: old value=1214, new value=3556, type=int
2018-02-02 16:38:51.806 Detail, Node023, Notification: ValueChanged
2018-02-02 16:38:51.808 Detail, Node023, Notification: ValueChanged
2018-02-02 16:38:51.810 Detail, Node023, Notification: ValueChanged
2018-02-02 16:38:51.813 Detail, Node023, Notification: ValueChanged
2018-02-02 16:38:51.913 Detail, Node023, Received: 0x01, 0x18, 0x00, 0x04, 0x00, 0x17, 0x12, 0x60, 0x0d, 0x05, 0x00, 0x32, 0x02, 0x21, 0x64, 0x00, 0x00, 0x00, 0x27, 0x12, 0xa2, 0x00, 0x00, 0x00, 0x0e, 0x62
