Does anyone have any experience with the Aeotec Dual Nano switch in Hass?
I have successfully added this to HASS, however it’s only showing a single Switch component. It’s meant to be able to control 2 switches individually. Instead I get a single switch that control both lights at the same time.
Hi @Kanishkaz, I run two of these in my house and they do show up. If you goto the developer tools > states and search for the switch you should find three entries for the same switch
example
switch.kitchen_lights_switch
switch.kitchen_lights_switch_2
switch.kitchen_lights_switch_3
The first two will relate to the physical switch. The third can be used to turn the first two on and off.
Cheers
Edit: just noticed you said nano. The above relates to the GEN5 dual switch, not sure if it will be the same with the nano
Yeah, I think the Nano switch is still very new. So I’m not sure if the OpenZwave config is up to date for this device. I’ve tried removing and adding this a couple of times now. It only shows one switch.
I’ve got the opposite problem. I see six switch entries. I am having trouble working out which one is actually controlling the switch and there is a lot of lag in updating the HASSIO interface. Anyone else using these?
