Aeotec Multisensor 5 - Can't change interval or on time
I’ve got a handful of Aeotec Multisensor 5 running on USB power, and I’m trying to lower the reporting interval, as well as the on time for the motion sensor, however, whenever I try to change the values in the Z-Wave Manager, it just reverts back to the previous value, even if I increase them.
I was previously able to change them using OZWCP (old method), but HA decided to delete the entire z-wave configuration a couple of hours ago after a reboot, so I had to start over.
You need to wake up the device first by pressing the action button. Then make the change and save it.
or you can use “Refresh Node”. I noticed it wakes up the device. Then change the settings and save it. I just did that and now the multisensor sends me updates every 30 seconds.
Hmm, I tried using Refresh Node, as well as pushing the button, but it wouldn’t take. I ended up just using OZWCP to set them back up, but it’s a bit of a hassle.
