HI,
How to configure Aeotec Multisensor 6 (ZW100 purchased in October 2018) on HASSIO / RPi.
-Where to place Aeotec multi sensor 6 in the configuration.yaml file.
-How to configure Aeotec Multisensor 6
motion detector to start a lamp for 10 minutes, and where the configuration is set in config.yaml.
-Do you have any examples of how you configured, on HASSIO / RPi
My current HASSIO version is: 0.83.2
Regards Christian
Do you have a zwave hub of some sort?
If HA is controlling the zwave network,did you add the sensor per the instructions below?
Get the sensor setup and identify the resultant entity_id for your motion sensor. We can work on the automation when that information is available.
Here is an example where I have a door sensor to turn on a light. Then it gets turned off after 5 minutes. It can be easily adapted to do what you ask.
Yes , I have a Aeotec ZW090 Z-Stick Gen5 EU
Can you give your example on config.yaml for motion sensor?
//Christian
Have you added the sensor to your Home Assistant instance?
yes, i have.
What is the entity ID and what are the states?
Here is my configuration.yaml file.
automation:
alias: Turn on kitchen light when there is movement
platform: state
entity_id: sensor.aeotec_zw100_multisensor_6_burglar_9_10
to: ‘on’
service: homeassistant.turn_on
entity_id: switch.telldus_tzwp100_plugin_switch_switch_4 -
alias: Turn off kitchen light 10 minutes after last movement
platform: state
to: ‘off’
for:
minutes: 10
service: homeassistant.turn_off
Can you format per the instruction in the blue bar at the top of every post?
Is the automation not working? Getting a configuration error?
The switch_4 does not turn on the lamp, when sensor aeotec6 has detected motion.
automation:
- alias: Turn on kitchen light when there is movement
platform: state
to: 'on'
- alias: Turn off kitchen light 10 minutes after last movement
platform: state
to: 'off'
for:
minutes: 10
My configuration doesn’t show the last _x_y after the burglar word in entity_id and then I switch on the light when the sensor get value 8 not on or true and switch off when 0 not false nor off
I hope it helps you
I would confirm your entity ID and your actual states in the states page of the developer tools.
