I have a MS 6 which has been in place for a year or so - running on standard CR123 batteries. Yesterday I changed it to use 3.0V (NOT 3.7v) rechargeable batteries - no other change.
Now every 15 minutes (wake up interval) it will always see that burglar state as 8, triggering a notiification alert I have set up on that condition.
4 minutes later, it will get a state 0 and then again on the wake up, go round again.
Could this be something to do with the batteries affecting the sensor in some way?
I’ve not tried putting back standard batteries, but does seem odd…
Here’s the log from OZW log file.
Currently running HA core 2021.5.5 version, OS 3.13 and the deprecated Z-Wave integration.
I’m not confident to upgrade to either the Z-save JS or new OS 6.1 - any thoughts?
2021-08-02 19:42:58.069 Detail, Node009, Received: 0x01, 0x0c, 0x00, 0x04, 0x10, 0x09, 0x06, 0x31, 0x05, 0x01, 0x22, 0x00, 0x9a, 0x65
2021-08-02 19:42:58.070 Info, Node009, Received SensorMultiLevel report from node 9, instance 1, Temperature: value=15.4C
2021-08-02 19:42:58.070 Detail, Node009, Refreshed Value: old value=15.6, new value=15.4, type=decimal
2021-08-02 19:42:58.070 Detail, Node009, Changes to this value are not verified
2021-08-02 19:42:58.070 Detail, Node009, Notification: ValueChanged
2021-08-02 19:42:59.546 Detail, Node009, Received: 0x01, 0x0b, 0x00, 0x04, 0x10, 0x09, 0x05, 0x31, 0x05, 0x05, 0x01, 0x4b, 0x97
2021-08-02 19:42:59.546 Info, Node009, Received SensorMultiLevel report from node 9, instance 1, Relative Humidity: value=75%
2021-08-02 19:42:59.546 Detail, Node009, Refreshed Value: old value=73, new value=75, type=decimal
2021-08-02 19:42:59.546 Detail, Node009, Changes to this value are not verified
2021-08-02 19:42:59.546 Detail, Node009, Notification: ValueChanged
2021-08-02 19:43:02.004 Detail, Node009, Received: 0x01, 0x09, 0x00, 0x04, 0x10, 0x09, 0x03, 0x80, 0x03, 0x64, 0x0f
2021-08-02 19:43:02.004 Info, Node009, Received Battery report from node 9: level=100
2021-08-02 19:43:02.004 Detail, Node009, Refreshed Value: old value=100, new value=100, type=byte
2021-08-02 19:43:02.004 Detail, Node009, Changes to this value are not verified
2021-08-02 19:43:02.004 Detail, Node009, Notification: ValueChanged
2021-08-02 19:43:06.271 Detail, Node009, Received: 0x01, 0x09, 0x00, 0x04, 0x10, 0x09, 0x03, 0x30, 0x03, 0xff, 0x24
2021-08-02 19:43:06.271 Info, Node009, Received SensorBinary report: Sensor:36 State=On
2021-08-02 19:43:06.271 Detail, Node009, Refreshed Value: old value=false, new value=true, type=bool
2021-08-02 19:43:06.271 Detail, Node009, Changes to this value are not verified
2021-08-02 19:43:06.271 Detail, Node009, Notification: ValueChanged
2021-08-02 19:43:07.805 Detail, Node009, Received: 0x01, 0x10, 0x00, 0x04, 0x10, 0x09, 0x0a, 0x71, 0x05, 0x00, 0x00, 0x00, 0xff, 0x07, 0x08, 0x00, 0x00, 0x7c
2021-08-02 19:43:07.805 Info, Node009, Received Alarm report: type=0, level=0, sensorSrcID=0, type:Burglar event:8, status=255
2021-08-02 19:43:07.805 Detail, Node009, Refreshed Value: old value=0, new value=0, type=byte
2021-08-02 19:43:07.805 Detail, Node009, Changes to this value are not verified
2021-08-02 19:43:07.806 Detail, Node009, Refreshed Value: old value=0, new value=0, type=byte
2021-08-02 19:43:07.806 Detail, Node009, Changes to this value are not verified
2021-08-02 19:43:07.806 Detail, Node009, Refreshed Value: old value=0, new value=8, type=byte
2021-08-02 19:43:07.807 Detail, Node009, Changes to this value are not verified
2021-08-02 19:43:07.807 Detail, Node009, Notification: ValueChanged
2021-08-02 19:43:07.831 Detail, Node009, Notification: ValueChanged
2021-08-02 19:43:07.844 Detail, Node009, Notification: ValueChanged
2021-08-02 19:43:07.857 Detail, Node009, Notification: ValueChanged
2021-08-02 19:43:10.299 Detail, Node009, Received: 0x01, 0x0c, 0x00, 0x04, 0x10, 0x09, 0x06, 0x31, 0x05, 0x03, 0x0a, 0x00, 0x00, 0xd5
2021-08-02 19:43:10.300 Info, Node009, Received SensorMultiLevel report from node 9, instance 1, Luminance: value=0lux
2021-08-02 19:43:10.300 Detail, Node009, Refreshed Value: old value=0, new value=0, type=decimal
2021-08-02 19:43:10.300 Detail, Node009, Changes to this value are not verified
2021-08-02 19:43:10.301 Detail, Node009, Notification: ValueChanged
2021-08-02 19:43:12.019 Detail, Node009, Received: 0x01, 0x0b, 0x00, 0x04, 0x10, 0x09, 0x05, 0x31, 0x05, 0x1b, 0x01, 0x00, 0xc2
2021-08-02 19:43:12.020 Info, Node009, Received SensorMultiLevel report from node 9, instance 1, Ultraviolet: value=0
2021-08-02 19:43:12.020 Detail, Node009, Refreshed Value: old value=0, new value=0, type=decimal
2021-08-02 19:43:12.022 Detail, Node009, Changes to this value are not verified
2021-08-02 19:43:12.023 Detail, Node009, Notification: ValueChanged
2021-08-02 19:43:13.307 Detail, Node009, Received: 0x01, 0x08, 0x00, 0x04, 0x10, 0x09, 0x02, 0x84, 0x07, 0x6b
2021-08-02 19:43:13.310 Info, Node009, Received Wakeup Notification from node 9
2021-08-02 19:43:13.311 Detail, Node009, Queuing (WakeUp) WakeUpCmd_NoMoreInformation (Node=9): 0x01, 0x09, 0x00, 0x13, 0x09, 0x02, 0x84, 0x08, 0x25, 0xe2, 0xa5
2021-08-02 19:47:04.284 Detail, Node009, Received: 0x01, 0x09, 0x00, 0x04, 0x10, 0x09, 0x03, 0x30, 0x03, 0x00, 0xdb
2021-08-02 19:47:04.284 Info, Node009, Received SensorBinary report: Sensor:219 State=Off
2021-08-02 19:47:04.284 Detail, Node009, Refreshed Value: old value=true, new value=false, type=bool
2021-08-02 19:47:04.285 Detail, Node009, Changes to this value are not verified
2021-08-02 19:47:04.285 Detail, Node009, Notification: ValueChanged
2021-08-02 19:47:06.089 Detail, Node009, Received: 0x01, 0x10, 0x00, 0x04, 0x10, 0x09, 0x0a, 0x71, 0x05, 0x00, 0x00, 0x00, 0xff, 0x07, 0x00, 0x00, 0x00, 0x74
2021-08-02 19:47:06.089 Info, Node009, Received Alarm report: type=0, level=0, sensorSrcID=0, type:Burglar event:0, status=255
2021-08-02 19:47:06.090 Detail, Node009, Refreshed Value: old value=0, new value=0, type=byte
2021-08-02 19:47:06.090 Detail, Node009, Changes to this value are not verified
2021-08-02 19:47:06.090 Detail, Node009, Refreshed Value: old value=8, new value=0, type=byte
2021-08-02 19:47:06.090 Detail, Node009, Notification: ValueChanged
