Aeotec multisensor 6: homekit Luminance
Hi.
I just started my journey with a home assistant.
I set up aeotek multisensor 6 through aotek z-stick and in the assistant everything is displayed correctly.
So, my next step - to connect homekit. I added homekit to configuration (like https://www.home-assistant.io/components/homekit/) with zwave.network_ready event starting. Also, i set custom device classes of limunance and humidity sensors.
Everything is ok except of luminance sensor value. If the value more than 0 - ok. But if room is dark and in assistant web ui it shows as 0.0, the homekit value stuck on previous one. For example, i turn on the light - value is 6, turn off - in assistant = 0, in homekit = 6.
How can i fix that?
I am also seeing this. Does anyone have anything we could try?
