Using the Multisensor 6 with zwave2mqtt is frustrating. But maybe you can help me by answering some of my questions below.
There are a lot of quirks when you look at the sensor readings and settings detected by zwave2mqtt and what is promoted to Home Assistant for auto discovery.
In the end I had to look at what zwave2mqtt detected, and what was sent to MQTT.
But I am not at all sure that what is detected is right:
Comment: PIR is configured to “Basic Set” not “Binary Sensor Report”, if this makes a difference.
binary_sensor_contact, 48/1/0, boolean, always reports “false”, but only together with other sensor values. Seems to have no function at all, at least I don’t see any immediate reports on this one, but maybe it is the tamper sensor that works differently? I thought it was about vibration sensing.
sensor_alarm_home_security, 113/1/7, no unit: always reports “unknown”, sends a report when motion is detected, so I assume it is the PIR motion detector. However, in zwave2mqtt log I find this:
2020-04-29 11:35:14.672 Detail, Node003, Received: 0x01, 0x09, 0x00, 0x04, 0x00, 0x03, 0x03, 0x20, 0x01, 0x00, 0xd3
2020-04-29 11:35:14.672 Info, Node003, ApplicationCommandHandler - Unhandled Command Class 0x20
2020-04-29 11:35:14.994 Detail, Node003, Received: 0x01, 0x0f, 0x00, 0x04, 0x00, 0x03, 0x09, 0x71, 0x05, 0x00, 0x00, 0x00, 0xff, 0x07, 0x00, 0x00, 0x72
2020-04-29 11:35:14.995 Detail,
2020-04-29 11:35:14.995 Warning, NotificationCCTypes::GetAlarmNotificationTypes - Unknown Alarm Type 7
2020-04-29 11:35:14.995 Warning, NotificationCCTypes::GetEventForAlarmType - Unknown AlarmType/Event 7/d
2020-04-29 11:35:14.996 Warning, NotificationCCTypes::GetAlarmType - Unknown AlarmType 7
2020-04-29 11:35:14.996 Info, Node003, Received Notification report (>v1): Type: Unknown (7) Event: Unknown (0) Status: true, Param Length: 0
2020-04-29 11:35:14.996 Detail, Node003, Refreshed Value: old value=0, new value=0, type=list
2020-04-29 11:35:14.997 Detail, Node003, Changes to this value are not verified
2020-04-29 11:35:14.997 Detail, Node003, Notification: ValueChanged
2020-04-29T09:35:14.998Z z2m:Zwave zwave node 3: changed: 113-1-7:Unknown:Unknown -> Unknown
Bottomline you get a state change from unknown to unknown, which is not helpful at all to detect the motion. Is is a bug in zwave2mqtt, is there a mapping missing somewhere? If I cannot do anything about it, what would you propose how to use such reports in home assistant to still get a state change for motion sensor entity?
Motion sensing is the most important part for me. If that does not work, all is lost with this sensor.
sensor_battery_level, 128/1/0, %: always 100 when on USB power, no batteries were included.
sensor_humidity_air, 49/1/5, RH: reports in deltas of 1, not sure how accurate the reported values are. This is somewhat interesting to display in the bathroom.
sensor_illuminance, 49/1/3, Lux: reports 0 in a dark room. 3 with some light, 127 with a flashlight in front of it. Not sure how accurate that is, but it seems to do something. This * sensor is the second most important to me for automation to determine how bright the light bulbs should illuminate.
sensor_sun_ultraviolet, 49/1/27, no unit: always 0 indoors AND outdoors. I don’t care about that sensor anyway.
sensor_temperature_air, 49/1/1, C: reports 5 degrees too high, calibration does not work (whatever I set as value for calibration, the setting will snap back to either 1 oder 255), insanely high threshold (3-112-1-41) of 1310976 and upper limit (3-112-1-49) of 18350336, and not possible to change them. Why these values, and why does it not update the values to what I am setting? Is my sensor broken or is there a problem with zwave2mqtt??
More quirks:
Trying to enable the change-threshold-based reporting (3-112-1-48) for temperature, illuminance, humidity etc. does not work. I was not able enable this for any of the defined change-thresholds. Is this a problem in zwave2mqtt or with the sensor?
The discovery JSON sent for Home Assistant auto discovery is missing the appropriate units.
