Aeotec Multisensor: Intermittent Polling
Hi All –
I paired successfully a Aeotec Multisensor 6 via a Z-Wave.me USB stick on HAAS on a Synology Diskstation. Pairing worked fine, I can get values from the sensor, however its polling is intermittent. Although the sensor is on USB continuously, I can see, based on the historical graphs, and also on the ‘last updated’ date that it doesn’t refresh every 3 minutes. The values in its configuration are the following:
  • 240 seconds: Wakeup
  • Command Options: Binary Sensor Report
  • On Time: 240
  • 111: Group 1 Interval: 180
On occasion, the sensor might reset itself, for example it happened that I had to go back and change the setting of ‘Command Options’ back to Binary from its default option.
What am I doing wrong?
Many thanks!
