Hi everyone,
I am setting up an Aeotec multisensor zw074 so that it turns on a lifx bulb when motion is detected. The code is working and I can get it to turn on the light. The problem is that the sensor wakes up when it detects movement but does not send a movement command until it detects movement again after the initial wakeup, this means that you can enter and leave the room without the light ever turning on. I have a fibaro sensor fgms-001 and it turns the lights on when any motion is detected. Does anyone know if this is working as intended or is there something I need to change in the setup?
