Does anyone know if the LED on this device can be controlled?
I have read through the documentation and it appears you can enable/disable it but I would like to adjust the time/colour that is used when motion is detected.
That’s not really possible.
It will flash blue when motion is detected and the device is connected securely to your zwave network.
It flashes green when you’re using an unsecured connection.
Other than that, turning on/off the LED is the only option.
In case that’s a feature your’re looking for: the Fibaro FGMS has a few more options controlling its LED (like the color being dependant on the room temperature).
Sebastian
