Just a heads up for everybody. I spent a lot of time trying to get Zwave running when I move from a 3B to a 3B+, I knew my aeotec stick was working on my old setup. The problem is the new POE Hat, as soon as I remove it everything works on my new setup.
Some more info:
On the new setup with POE Hat I keep getting the following error:
WARNING (Dummy-6) [openzwave] Z-Wave Notification DriverFailed : {‘notificationType’: ‘DriverFailed’, ‘homeId’: 0, ‘nodeId’: 255}
And if I look at Zwave management i got:
2018-09-04 08:22:36.803 Always, OpenZwave Version 1.4.3142 Starting Up
2018-09-04 08:24:04.681 Info, Setting Up Provided Network Key for Secure Communications
2018-09-04 08:24:04.681 Warning, Failed - Network Key Not Set
2018-09-04 08:24:04.686 Info, mgr, Added driver for controller /dev/ttyAMA0
2018-09-04 08:24:04.686 Info, Opening controller /dev/ttyAMA0
2018-09-04 08:24:04.687 Info, Trying to open serial port /dev/ttyAMA0 (attempt 1)
2018-09-04 08:24:04.687 Info, Serial port /dev/ttyAMA0 opened (attempt 1)
2018-09-04 08:24:04.698 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_GET_VERSION: 0x01, 0x03, 0x00, 0x15, 0xe9
2018-09-04 08:24:04.699 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_MEMORY_GET_ID: 0x01, 0x03, 0x00, 0x20, 0xdc
2018-09-04 08:24:04.699 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_GET_CONTROLLER_CAPABILITIES: 0x01, 0x03, 0x00, 0x05, 0xf9
2018-09-04 08:24:04.699 Detail, contrlr, Queuing (Command) FUNC_ID_SERIAL_API_GET_CAPABILITIES: 0x01, 0x03, 0x00, 0x07, 0xfb
2018-09-04 08:24:04.699 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_GET_SUC_NODE_ID: 0x01, 0x03, 0x00, 0x56, 0xaa
2018-09-04 08:24:04.699 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x15) - FUNC_ID_ZW_GET_VERSION: 0x01, 0x03, 0x00, 0x15, 0xe9
2018-09-04 08:24:04.700 Detail, contrlr, Notification: DriverFailed
