Hey Folks,
I have started to play around with Zwave-js and have noticed some inconsistencies with my Aeotec devices and the power sensor(s). I moved over from Vera where I am trying to get feature parity for power usage per device working in HASS.
I have a bunch of Micro Smart Energy Sensors (DSC12) which have Multilevel Sensor for Power usage (23-49-0-Power) These work well.
However i also have a bunch of the Micro Smart Energy Illuminator G2 (DSC19), Micro Smart Energy Switch G2 (DSC18), Aeotec Nano Switch (ZW116), Nano Dimmer (ZW111). None od these have the same power sensor output as the above, instead there is a βMeterβ section in zwavejs2mqtt that appears to store accumulated power stats, not real time. I have had a look through the forums and initially thought the reason these stats were not working correctly was due to polling, however further investigation shows that these devices are not presenting real time power consumption to zwave-js.
Has anyone seen this and does anyone know id there is away to extract real time power consumption for these things.
TIA
