Aeotec Provided 7.20.2 Firmware for USB 700 Stick
So I updated the Gen-7 stick with 21.2 firmware 3 days ago (from 20.2)
Two days is not much of statistical data, but I already see that the jamming issue is NOT solved, I had 3 jams yesterday and 2 already today.
If someone from Aeotec and/or SiliconLab is following this forum discussion: Could you put some more effort in solving this jamming and locking issue. If this helps you, I have now two months of full ZwaveJS-UI logs that I can make available for analysis (based on 66 ZWave devices, mix of battery and direct powered).
For now, I keep on logging for a few days, then go on holiday, but thereafter I plan to change the Gen-7 for a Gen-5 stick and see whether I get a better performance. I started with HA ZWave 3 months ago (coming from a Fibaro HC2 system), and I’m quite disappointed with the Aeotec Gen-7.
Question: I have no experience with Z-wave 700 based sticks from other vendors, do those have similar issues (I image so, but am not sure). Any update on this would be appreciated
