Aeotec Smart Switch 6 reporting strangely
I just got a Aeotec Smart Switch 6 and got it paired to my Z-Stick. Originally I was only getting KWh readings and the switch status. I wanted live wattage readings so used openzwave control panel to configure paramater 101 to 15, which should report both. It now reports both in HA, but as a single “sensor”. meaning my single value changes from “x” KWh to “x” W, every 3 seconds, since that is the reporting time in the Smart Switch. I can upload a video tomorrow of it changing between values…
Thanks for any help. I am new to HA and Z-Wave but am loving it so far.
Video is here: https://youtu.be/S0tRl8IUTL4
I contacted AeoTec support and they said the switch is reporting data correctly, but the software isn’t reading it right. Does anyone else have one of the SmartSwitch6 units, and if so, does your data come in correctly?
For whatever reason it started working after I unpaired the SS6 from my Z-Stick, reset the SS6 to defaults, then repaired. Everything is reporting correctly now.
