Hi there,
I moved to a new house recently and I’m slowly rebuilding my Home Assistant environment. I moved from RPi 3b+ to an Intel NUC and upgrade the controller from the Aotec USB stick Gen5 to Z-Stick 7. I had a few issues at the beginning because I was using an USB extender and I was getting a ton of ACK timeouts on the controller. I removed it and now it is fine. I have a few RX/TX dropped though, not sure if it is an issue or not.
I’m facing a weird behaviour with the Smart Switch 7 plugs which I have for a while now and I have never had any issues so far (at least not this kind of problem). Even if I sent the reporting interval to 60 seconds, some plugs won’t send any updates. Sometimes, maybe 2 or 3 hours later I will have an update.
I notice something: if I configure everything in one go (reset to factory defaults, reinclusion) without unplugging the device from the power socket, the plug will send some updates (kwh, A, W) every 60 seconds. The moment I unplug/replug the switch, it starts not working.
I don’t understand what can be wrong. My devices seem paired and working well from a Z-Wave standpoint. I had in the past some issues with the Home Energy Meter which which stopped reporting as well. It was related to groups in Z-Wave configurations. In my current case, I can see that each device has a rule by default:
Any thoughts on this? Should I contact Aoetec as well to see what they have to say?
Thanks,
G.
