Aeotec Stick + Door/Window Sensor 6 - always asleep / not seeing any state change
Hi there,
Day 1 of Z-Wave for me, so this is probably a really basic noob question…
I have setup my Z-Wave stick using the standard HA Integration. I’ve paired the sensor and it appears to be working.
But the sesnors says it’s always sleeping. Is this normal?
If I move the magnet near it, I see the ‘receivedCnt’ increasing.
But the value of it’s binary_sensor never changes.
Any tips?
This is the sensor:
These are the rentities it’s made:
and the output always looks like this:
Even when I see the green light on the sensor flash when I move the magnet…
What’s the rest of your setup? (Raspberry Pi 4 needs a non-powered USB 2.0 hub to use the Aeotec Stick)
Are any values of the device updating (even if it’s the one of your screenshot that shows the Sleeping state), as it is a battery powered sensor it will sleep continuously and only contact on a set interval or on a state change (magnet). Do you have other devices that are working? I would suspect the Sensor to switch to Off in case of an open door (disconnected magnet)
Hi Rick,
Thanks for the reply. I just bought the z-wave stick, and it is the latest version which is meant to work on a pi4 without a hub: https://popp.to/collections/z-wave-gateways/products/aeotec-z-stick-gen5-zw090?utm_source=Aeotec-com&utm_medium=web&utm_campaign=w2b
But I can try with one as a test.
I am using a Raspberry PI 4, the z-wave stick is plugged straight into it. I also have a ConBee II plugged in.
The Z-wave stick is approx 15m from the sensor (which is the only z-wave device I have at the moment, with about 4 wall between them).
If I move the magnet the green light flickers on and off on the sensor, so I assume it’s working.
I just uninstalled and reinstalled the Z-Wave integration (I am using just that the one in the integrations list, I have installed nothing from the add-ons list in the supervisor section)
I have been trying various things over the last few days and this is what’s happening.
The 2 devices show up fine.
The sensor is still ‘CacheLoad’ after 15 mins) - it normally becomes complete evenutally… Ill wait till that happens to test… 1hr later still on CacheLoad and it isn’t responding.
(Previously, when it does become complete. It is unpredictable. it can do 1 of 3 things:
Work normally
Change state once and then remain stuck
not change state at all
But the SendCnt/ReceivedCnt and SendTS/ReceivedTS will change when I move the sensor.)
Do you think it could be too far away, as an only sensor?
Thanks, any tips/tricks appreciated! :slight_smile:
I’ll include the current logs:
2020-09-15 19:01:14.059 Always, OpenZwave Version 1.4.3469 Starting Up
2020-09-15 19:01:24.022 Info, Setting Up Provided Network Key for Secure Communications
2020-09-15 19:01:24.022 Info, mgr,     Added driver for controller /dev/ttyACM0
2020-09-15 19:01:24.023 Info,   Opening controller /dev/ttyACM0
2020-09-15 19:01:24.023 Info, Trying to open serial port /dev/ttyACM0 (attempt 1)
2020-09-15 19:01:24.025 Info, Serial port /dev/ttyACM0 opened (attempt 1)
2020-09-15 19:01:24.026 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_GET_VERSION: 0x01, 0x03, 0x00, 0x15, 0xe9
2020-09-15 19:01:24.026 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_MEMORY_GET_ID: 0x01, 0x03, 0x00, 0x20, 0xdc
2020-09-15 19:01:24.026 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_GET_CONTROLLER_CAPABILITIES: 0x01, 0x03, 0x00, 0x05, 0xf9
2020-09-15 19:01:24.026 Detail, contrlr, Queuing (Command) FUNC_ID_SERIAL_API_GET_CAPABILITIES: 0x01, 0x03, 0x00, 0x07, 0xfb
2020-09-15 19:01:24.026 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_GET_SUC_NODE_ID: 0x01, 0x03, 0x00, 0x56, 0xaa
2020-09-15 19:01:24.027 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x15) - FUNC_ID_ZW_GET_VERSION: 0x01, 0x03, 0x00, 0x15, 0xe9
2020-09-15 19:01:24.029 Detail, contrlr,   Received: 0x01, 0x10, 0x01, 0x15, 0x5a, 0x2d, 0x57, 0x61, 0x76, 0x65, 0x20, 0x34, 0x2e, 0x35, 0x34, 0x00, 0x01, 0x93
2020-09-15 19:01:24.029 Info, contrlr, Received reply to FUNC_ID_ZW_GET_VERSION:
2020-09-15 19:01:24.029 Info, contrlr,     Static Controller library, version Z-Wave 4.54
2020-09-15 19:01:24.029 Detail, Node045,   Expected reply was received
2020-09-15 19:01:24.029 Detail, Node045,   Message transaction complete
2020-09-15 19:01:24.029 Detail, contrlr, Removing current message
2020-09-15 19:01:24.030 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x20) - FUNC_ID_ZW_MEMORY_GET_ID: 0x01, 0x03, 0x00, 0x20, 0xdc
2020-09-15 19:01:24.035 Detail, contrlr,   Received: 0x01, 0x08, 0x01, 0x20, 0xd1, 0x6a, 0xc5, 0x81, 0x01, 0x28
2020-09-15 19:01:24.035 Info, contrlr, Received reply to FUNC_ID_ZW_MEMORY_GET_ID. Home ID = 0xd16ac581.  Our node ID = 1
2020-09-15 19:01:24.035 Detail, Node106,   Expected reply was received
2020-09-15 19:01:24.035 Detail, Node106,   Message transaction complete
2020-09-15 19:01:24.035 Detail, contrlr, Removing current message
2020-09-15 19:01:24.035 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x05) - FUNC_ID_ZW_GET_CONTROLLER_CAPABILITIES: 0x01, 0x03, 0x00, 0x05, 0xf9
2020-09-15 19:01:24.038 Detail, contrlr,   Received: 0x01, 0x04, 0x01, 0x05, 0x08, 0xf7
2020-09-15 19:01:24.040 Detail,
2020-09-15 19:01:24.040 Info, contrlr, Received reply to FUNC_ID_ZW_GET_CONTROLLER_CAPABILITIES:
2020-09-15 19:01:24.040 Info, contrlr,     There is no SUC ID Server (SIS) in this network.
2020-09-15 19:01:24.040 Info, contrlr,     The PC controller is a primary controller.
2020-09-15 19:01:24.040 Detail, Node247,   Expected reply was received
2020-09-15 19:01:24.040 Detail, Node247,   Message transaction complete
2020-09-15 19:01:24.040 Detail, contrlr, Removing current message
2020-09-15 19:01:24.040 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x07) - FUNC_ID_SERIAL_API_GET_CAPABILITIES: 0x01, 0x03, 0x00, 0x07, 0xfb
2020-09-15 19:01:24.044 Detail, contrlr,   Received: 0x01, 0x2b, 0x01, 0x07, 0x01, 0x01, 0x00, 0x86, 0x02, 0x01, 0x00, 0x5a, 0xfe, 0x81, 0xff, 0x88, 0x4f, 0x1f, 0x00, 0x00, 0xfb, 0x9f, 0x7d, 0xa0, 0x67, 0x00, 0x00, 0x80, 0x00, 0x80, 0x86, 0x00, 0x00, 0x00, 0xe8, 0x73, 0x00, 0x00, 0x0e, 0x00, 0x00, 0x60, 0x00, 0x00, 0xf8
2020-09-15 19:01:24.044 Info, contrlr,  Received reply to FUNC_ID_SERIAL_API_GET_CAPABILITIES
2020-09-15 19:01:24.044 Info, contrlr,     Serial API Version:   1.1
2020-09-15 19:01:24.044 Info, contrlr,     Manufacturer ID:      0x0086
2020-09-15 19:01:24.044 Info, contrlr,     Product Type:         0x0201
2020-09-15 19:01:24.044 Info, contrlr,     Product ID:           0x005a
2020-09-15 19:01:24.044 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_GET_RANDOM: 0x01, 0x04, 0x00, 0x1c, 0x20, 0xc7
2020-09-15 19:01:24.044 Detail, contrlr, Queuing (Command) FUNC_ID_SERIAL_API_GET_INIT_DATA: 0x01, 0x03, 0x00, 0x02, 0xfe
2020-09-15 19:01:24.044 Detail, contrlr, Queuing (Command) FUNC_ID_SERIAL_API_SET_TIMEOUTS: 0x01, 0x05, 0x00, 0x06, 0x64, 0x0f, 0x97
2020-09-15 19:01:24.044 Detail, contrlr, Queuing (Command) FUNC_ID_SERIAL_API_APPL_NODE_INFORMATION: 0x01, 0x07, 0x00, 0x03, 0x01, 0x02, 0x01, 0x00, 0xf9
2020-09-15 19:01:24.044 Detail, Node001,   Expected reply was received
2020-09-15 19:01:24.044 Detail, Node001,   Message transaction complete
2020-09-15 19:01:24.044 Detail, contrlr, Removing current message
2020-09-15 19:01:24.044 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x56) - FUNC_ID_ZW_GET_SUC_NODE_ID: 0x01, 0x03, 0x00, 0x56, 0xaa
2020-09-15 19:01:24.046 Detail, contrlr,   Received: 0x01, 0x04, 0x01, 0x56, 0x00, 0xac
2020-09-15 19:01:24.046 Info, contrlr, Received reply to GET_SUC_NODE_ID.  Node ID = 0
2020-09-15 19:01:24.046 Info, Controller Does not Support SUC - Cannot Setup Controller as SUC Node
2020-09-15 19:01:24.046 Detail, Node172,   Expected reply was received
2020-09-15 19:01:24.046 Detail, Node172,   Message transaction complete
2020-09-15 19:01:24.046 Detail, contrlr, Removing current message
2020-09-15 19:01:24.046 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x1c) - FUNC_ID_ZW_GET_RANDOM: 0x01, 0x04, 0x00, 0x1c, 0x20, 0xc7
2020-09-15 19:01:24.102 Detail, contrlr,   Received: 0x01, 0x25, 0x01, 0x1c, 0x01, 0x20, 0xe1, 0xa3, 0xa1, 0x9c, 0xfb, 0x59, 0x97, 0x00, 0x3b, 0xe5, 0x9a, 0x45, 0x92, 0xa7, 0x24, 0x8e, 0xdb, 0x83, 0x3c, 0x9d, 0x3b, 0x0a, 0x6c, 0xde, 0xed, 0x31, 0x75, 0x26, 0xab, 0x67, 0xc0, 0x25, 0xee
2020-09-15 19:01:24.102 Info, contrlr, Received reply to FUNC_ID_ZW_GET_RANDOM: true
2020-09-15 19:01:24.102 Detail, Node032,   Expected reply was received
2020-09-15 19:01:24.102 Detail, Node032,   Message transaction complete
2020-09-15 19:01:24.102 Detail, contrlr, Removing current message
2020-09-15 19:01:24.102 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x02) - FUNC_ID_SERIAL_API_GET_INIT_DATA: 0x01, 0x03, 0x00, 0x02, 0xfe
2020-09-15 19:01:24.207 Detail, contrlr,   Received: 0x01, 0x25, 0x01, 0x02, 0x05, 0x00, 0x1d, 0x09, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x05, 0x00, 0xcd
2020-09-15 19:01:24.207 Info, mgr,     Driver with Home ID of 0xd16ac581 is now ready.
2020-09-15 19:01:24.214 Info, contrlr, Received reply to FUNC_ID_SERIAL_API_GET_INIT_DATA:
2020-09-15 19:01:24.214 Info, contrlr,     Node 001 - Known
2020-09-15 19:01:24.214 Detail, Node001, AdvanceQueries queryPending=0 queryRetries=0 queryStage=CacheLoad live=1
2020-09-15 19:01:24.214 Detail, Node001, QueryStage_CacheLoad
2020-09-15 19:01:24.214 Info, Node001, Node Identity Codes: 0086:0201:005a
2020-09-15 19:01:24.214 Detail, Node001, QueryStage_Associations
2020-09-15 19:01:24.215 Detail, Node001, QueryStage_Neighbors
2020-09-15 19:01:24.215 Detail, contrlr, Requesting routing info (neighbor list) for Node 1
2020-09-15 19:01:24.215 Detail, Node001, Queuing (Command) Get Routing Info (Node=1): 0x01, 0x07, 0x00, 0x80, 0x01, 0x00, 0x00, 0x03, 0x7a
2020-09-15 19:01:24.215 Detail, Node001, Queuing (Query) Query Stage Complete (Neighbors)
2020-09-15 19:01:24.215 Info, contrlr,     Node 004 - Known
2020-09-15 19:01:24.215 Detail, Node004, AdvanceQueries queryPending=0 queryRetries=0 queryStage=CacheLoad live=1
2020-09-15 19:01:24.215 Detail, Node004, QueryStage_CacheLoad
2020-09-15 19:01:24.215 Info, Node004, Node Identity Codes: 0086:0202:0070
2020-09-15 19:01:24.215 Info, Node004, NoOperation::Set - Routing=true
2020-09-15 19:01:24.215 Detail, Node004, Queuing (NoOp) NoOperation_Set (Node=4): 0x01, 0x09, 0x00, 0x13, 0x04, 0x02, 0x00, 0x00, 0x25, 0x0a, 0xcc
2020-09-15 19:01:24.215 Detail, Node004, Queuing (Query) Query Stage Complete (CacheLoad)
2020-09-15 19:01:24.217 Detail,   Expected reply was received
2020-09-15 19:01:24.217 Detail,   Message transaction complete
2020-09-15 19:01:24.217 Detail, contrlr, Removing current message
2020-09-15 19:01:24.217 Detail, Node001, Notification: DriverReady
2020-09-15 19:01:24.221 Detail, Node001, Notification: NodeAdded
2020-09-15 19:01:24.227 Detail, Node001, Notification: NodeProtocolInfo
2020-09-15 19:01:24.231 Detail, Node001, Notification: EssentialNodeQueriesComplete
2020-09-15 19:01:24.234 Detail, Node001, Notification: ValueAdded
2020-09-15 19:01:24.237 Detail, Node001, Notification: NodeNaming
2020-09-15 19:01:24.240 Detail, Node004, Notification: NodeAdded
2020-09-15 19:01:24.244 Detail, Node004, Notification: NodeProtocolInfo
2020-09-15 19:01:24.246 Detail, Node004, Notification: EssentialNodeQueriesComplete
2020-09-15 19:01:24.247 Detail, Node004, Notification: ValueAdded
2020-09-15 19:01:24.251 Detail, Node004, Notification: ValueAdded
2020-09-15 19:01:24.261 Detail, Node004, Notification: ValueAdded
2020-09-15 19:01:24.281 Detail, Node004, Notification: ValueAdded
2020-09-15 19:01:24.292 Detail, Node004, Notification: ValueAdded
2020-09-15 19:01:24.300 Detail, Node004, Notification: ValueAdded
2020-09-15 19:01:24.310 Detail, Node004, Notification: ValueAdded
2020-09-15 19:01:24.319 Detail, Node004, Notification: ValueAdded
2020-09-15 19:01:24.324 Detail, Node004, Notification: ValueAdded
2020-09-15 19:01:24.328 Detail, Node004, Notification: ValueAdded
2020-09-15 19:01:24.333 Detail, Node004, Notification: ValueAdded
2020-09-15 19:01:24.336 Detail, Node004, Notification: ValueAdded
2020-09-15 19:01:24.341 Detail, Node004, Notification: ValueAdded
2020-09-15 19:01:24.345 Detail, Node004, Notification: ValueAdded
2020-09-15 19:01:24.356 Detail, Node004, Notification: ValueAdded
2020-09-15 19:01:24.366 Detail, Node004, Notification: ValueAdded
2020-09-15 19:01:24.376 Detail, Node004, Notification: ValueAdded
2020-09-15 19:01:24.395 Detail, Node004, Notification: ValueAdded
2020-09-15 19:01:24.398 Detail, Node004, Notification: ValueAdded
2020-09-15 19:01:24.405 Detail, Node004, Notification: ValueAdded
2020-09-15 19:01:24.410 Detail, Node004, Notification: ValueAdded
2020-09-15 19:01:24.416 Detail, Node004, Notification: ValueAdded
2020-09-15 19:01:24.422 Detail, Node004, Notification: ValueAdded
2020-09-15 19:01:24.427 Detail, Node004, Notification: ValueAdded
2020-09-15 19:01:24.431 Detail, Node004, Notification: ValueAdded
2020-09-15 19:01:24.441 Detail, Node004, Notification: ValueAdded
2020-09-15 19:01:24.456 Detail, Node004, Notification: ValueAdded
2020-09-15 19:01:24.464 Detail, Node004, Notification: ValueAdded
2020-09-15 19:01:24.486 Detail, Node004, Notification: ValueAdded
2020-09-15 19:01:24.490 Detail, Node004, Notification: ValueAdded
2020-09-15 19:01:24.495 Detail, Node004, Notification: ValueAdded
2020-09-15 19:01:24.501 Detail, Node004, Notification: ValueAdded
2020-09-15 19:01:24.507 Detail, Node004, Notification: ValueAdded
2020-09-15 19:01:24.513 Detail, Node004, Notification: Group
2020-09-15 19:01:24.524 Detail, Node004, Notification: ValueAdded
2020-09-15 19:01:24.531 Detail, Node004, Notification: ValueAdded
2020-09-15 19:01:24.537 Detail, Node004, Notification: ValueAdded
2020-09-15 19:01:24.543 Detail, Node004, Notification: NodeNaming
2020-09-15 19:01:24.546 Detail,
2020-09-15 19:01:24.546 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x06) - FUNC_ID_SERIAL_API_SET_TIMEOUTS: 0x01, 0x05, 0x00, 0x06, 0x64, 0x0f, 0x97
2020-09-15 19:01:24.547 Detail, contrlr,   Received: 0x01, 0x05, 0x01, 0x06, 0x64, 0x0f, 0x96
2020-09-15 19:01:24.547 Info, contrlr, Received reply to FUNC_ID_SERIAL_API_SET_TIMEOUTS
2020-09-15 19:01:24.547 Detail, Node015,   Expected reply was received
2020-09-15 19:01:24.547 Detail, Node015,   Message transaction complete
2020-09-15 19:01:24.547 Detail, contrlr, Removing current message
2020-09-15 19:01:24.547 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x00) - FUNC_ID_SERIAL_API_APPL_NODE_INFORMATION: 0x01, 0x07, 0x00, 0x03, 0x01, 0x02, 0x01, 0x00, 0xf9
2020-09-15 19:01:24.549 Detail, contrlr, Removing current message
2020-09-15 19:01:24.549 Info, Node001, Sending (Command) message (Callback ID=0x00, Expected Reply=0x80) - Get Routing Info (Node=1): 0x01, 0x07, 0x00, 0x80, 0x01, 0x00, 0x00, 0x03, 0x7a
2020-09-15 19:01:24.555 Detail, Node001,   Received: 0x01, 0x20, 0x01, 0x80, 0x08, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x56
2020-09-15 19:01:24.555 Info, Node001, Received reply to FUNC_ID_ZW_GET_ROUTING_INFO
2020-09-15 19:01:24.555 Info, Node001,     Neighbors of this node are:
2020-09-15 19:01:24.555 Info, Node001,     Node 4
2020-09-15 19:01:24.555 Detail,   Expected reply was received
2020-09-15 19:01:24.555 Detail,   Message transaction complete
2020-09-15 19:01:24.555 Detail, Node001, Removing current message
2020-09-15 19:01:24.555 Info, Node004, Sending (NoOp) message (Callback ID=0x0a, Expected Reply=0x13) - NoOperation_Set (Node=4): 0x01, 0x09, 0x00, 0x13, 0x04, 0x02, 0x00, 0x00, 0x25, 0x0a, 0xcc
2020-09-15 19:01:24.566 Detail, Node004,   Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2020-09-15 19:01:24.567 Detail, Node004,   ZW_SEND_DATA delivered to Z-Wave stack
2020-09-15 19:01:28.664 Detail, Node004,   Received: 0x01, 0x07, 0x00, 0x13, 0x0a, 0x01, 0x01, 0x9a, 0x7b
2020-09-15 19:01:28.664 Detail, Node004,   ZW_SEND_DATA Request with callback ID 0x0a received (expected 0x0a)
2020-09-15 19:01:28.664 Info, Node004, WARNING: ZW_SEND_DATA failed. No ACK received - device may be asleep.
2020-09-15 19:01:28.664 Info, Node004,   Node 4 has been marked as asleep
2020-09-15 19:01:28.664 Info, Node004, Node not responding - moving QueryStageComplete command to Wake-Up queue
2020-09-15 19:01:28.664 Detail, Node004, Notification: Notification - NoOperation
2020-09-15 19:01:28.668 Detail, Node004, Notification: Notification - Node Asleep
2020-09-15 19:01:28.674 Detail, Node001, Query Stage Complete (Neighbors)
2020-09-15 19:01:28.675 Detail, Node001, AdvanceQueries queryPending=0 queryRetries=0 queryStage=Session live=1
2020-09-15 19:01:28.675 Detail, Node001, QueryStage_Session
2020-09-15 19:01:28.676 Detail, Node001, QueryStage_Dynamic
2020-09-15 19:01:28.676 Detail, Node001, QueryStage_Configuration
2020-09-15 19:01:28.676 Detail, Node001, QueryStage_Complete
2020-09-15 19:01:28.676 Warning, CheckCompletedNodeQueries m_allNodesQueried=0 m_awakeNodesQueried=0
2020-09-15 19:01:28.676 Warning, CheckCompletedNodeQueries all=0, deadFound=0 sleepingOnly=1
2020-09-15 19:01:28.677 Info,          Node query processing complete except for sleeping nodes.
2020-09-15 19:01:28.677 Detail, Node001, Notification: NodeQueriesComplete
2020-09-15 19:01:28.684 Detail, contrlr, Notification: AwakeNodesQueried
2020-09-15 19:12:53.890 Detail, Node001, Queuing (Controller) Request Node Neighbor Update
2020-09-15 19:12:53.890 Detail, Node004, Queuing (Controller) Request Node Neighbor Update
2020-09-15 19:12:53.890 Info, Requesting Neighbor Update for node 1
2020-09-15 19:12:53.891 Detail, Node001, Queuing (Command) ControllerCommand_RequestNodeNeighborUpdate (Node=1): 0x01, 0x05, 0x00, 0x48, 0x01, 0x0b, 0xb8
2020-09-15 19:12:53.891 Detail, Notification: ControllerCommand - Starting
2020-09-15 19:12:53.894 Detail,
2020-09-15 19:12:53.894 Info, Node001, Sending (Command) message (Callback ID=0x0b, Expected Reply=0x48) - ControllerCommand_RequestNodeNeighborUpdate (Node=1): 0x01, 0x05, 0x00, 0x48, 0x01, 0x0b, 0xb8
2020-09-15 19:12:53.919 Detail, Node001,   Received: 0x01, 0x05, 0x00, 0x48, 0x0b, 0x23, 0x9a
2020-09-15 19:12:53.919 Warning, Node001, WARNING: REQUEST_NEIGHBOR_UPDATE_FAILED
2020-09-15 19:12:53.919 Detail, Node035,   Expected callbackId was received
2020-09-15 19:12:53.919 Detail, Node035,   Expected reply was received
2020-09-15 19:12:53.920 Detail, Node035,   Message transaction complete
2020-09-15 19:12:53.920 Detail, Node001, Removing current message
2020-09-15 19:12:53.920 Detail, Notification: ControllerCommand - Failed
2020-09-15 19:12:53.921 Info, Requesting Neighbor Update for node 4
2020-09-15 19:12:53.921 Detail,
2020-09-15 19:12:53.921 Detail, Node004, Queuing (Controller) Request Node Neighbor Update
2020-09-15 19:12:53.921 Detail, Notification: ControllerCommand - Starting
2020-09-15 19:12:53.922 Detail, Notification: ControllerCommand - Sleeping
2020-09-15 19:12:55.504 Info, Node004, NoOperation::Set - Routing=true
2020-09-15 19:12:55.505 Detail,
2020-09-15 19:12:55.505 Detail, Node004, Queuing (WakeUp) NoOperation_Set (Node=4): 0x01, 0x09, 0x00, 0x13, 0x04, 0x02, 0x00, 0x00, 0x25, 0x0d, 0xcb
2020-09-15 19:58:48.712 Info, Node004, NoOperation::Set - Routing=true
2020-09-15 19:58:48.712 Detail,
2020-09-15 19:58:48.712 Detail, Node004, Queuing (WakeUp) NoOperation_Set (Node=4): 0x01, 0x09, 0x00, 0x13, 0x04, 0x02, 0x00, 0x00, 0x25, 0x0e, 0xc8
2020-09-15 20:01:01.534 Detail, Node004,   Received: 0x01, 0x08, 0x00, 0x04, 0x00, 0x04, 0x02, 0x84, 0x07, 0x76
2020-09-15 20:01:01.534 Info, Node004, Received Wakeup Notification from node 4
2020-09-15 20:01:01.534 Info, Node004,   Node 4 has been marked as awake
2020-09-15 20:01:01.534 Detail, Node004, Queuing (Query) Query Stage Complete (CacheLoad)
2020-09-15 20:01:01.534 Detail, Node004, Queuing (Controller) Request Node Neighbor Update
2020-09-15 20:01:01.534 Detail, Node004, Queuing (WakeUp) NoOperation_Set (Node=4): 0x01, 0x09, 0x00, 0x13, 0x04, 0x02, 0x00, 0x00, 0x25, 0x0e, 0xc8
2020-09-15 20:01:01.534 Detail, Node004, Notification: Notification - Node Awake
2020-09-15 20:01:01.540 Info, Requesting Neighbor Update for node 4
2020-09-15 20:01:01.540 Detail, Node004, Queuing (Command) ControllerCommand_RequestNodeNeighborUpdate (Node=4): 0x01, 0x05, 0x00, 0x48, 0x04, 0x0f, 0xb9
2020-09-15 20:01:01.540 Detail, Notification: ControllerCommand - Starting
2020-09-15 20:01:01.543 Detail,
2020-09-15 20:01:01.543 Info, Node004, Sending (Command) message (Callback ID=0x0f, Expected Reply=0x48) - ControllerCommand_RequestNodeNeighborUpdate (Node=4): 0x01, 0x05, 0x00, 0x48, 0x04, 0x0f, 0xb9
2020-09-15 20:01:01.576 Detail, Node004,   Received: 0x01, 0x05, 0x00, 0x48, 0x0f, 0x21, 0x9c
2020-09-15 20:01:01.576 Info, Node004, REQUEST_NEIGHBOR_UPDATE_STARTED
2020-09-15 20:01:01.576 Detail, Node033,   Expected callbackId was received
2020-09-15 20:01:01.576 Detail, Node033,   Expected reply was received
2020-09-15 20:01:01.576 Detail, Node033,   Message transaction complete
2020-09-15 20:01:01.576 Detail, Node004, Removing current message
2020-09-15 20:01:01.576 Detail, Notification: ControllerCommand - InProgress
2020-09-15 20:01:01.577 Info, WriteNextMsg Controller nothing to do
2020-09-15 20:01:09.287 Detail,   Received: 0x01, 0x05, 0x00, 0x48, 0x0f, 0x23, 0x9e
2020-09-15 20:01:09.288 Detail,
2020-09-15 20:01:09.288 Warning, WARNING: REQUEST_NEIGHBOR_UPDATE_FAILED
2020-09-15 20:01:09.288 Detail, Notification: ControllerCommand - Failed
2020-09-15 20:01:09.289 Detail,
2020-09-15 20:01:09.289 Info, Node004, Sending (WakeUp) message (Callback ID=0x0e, Expected Reply=0x13) - NoOperation_Set (Node=4): 0x01, 0x09, 0x00, 0x13, 0x04, 0x02, 0x00, 0x00, 0x25, 0x0e, 0xc8
2020-09-15 20:01:09.303 Detail, Node004,   Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2020-09-15 20:01:09.303 Detail, Node004,   ZW_SEND_DATA delivered to Z-Wave stack
2020-09-15 20:01:13.398 Detail, Node004,   Received: 0x01, 0x07, 0x00, 0x13, 0x0e, 0x01, 0x01, 0x9a, 0x7f
2020-09-15 20:01:13.398 Detail, Node004,   ZW_SEND_DATA Request with callback ID 0x0e received (expected 0x0e)
2020-09-15 20:01:13.398 Info, Node004, WARNING: ZW_SEND_DATA failed. No ACK received - device may be asleep.
2020-09-15 20:01:13.398 Info, Node004,   Node 4 has been marked as asleep
2020-09-15 20:01:13.398 Info, Node004, Node not responding - moving QueryStageComplete command to Wake-Up queue
2020-09-15 20:01:13.398 Detail, Node004, Notification: Notification - NoOperation
2020-09-15 20:01:13.402 Detail, Node004, Notification: Notification - Node Asleep
15 meters with 4 walls is a lot. For testing purposes you could bring the devices closer to each other, to make sure your network is functioning fine. According to the device configuration options in the manual you cannot specify the wake up interval, but you can push the action button on the sensor to wake it up manually and make sure it finishes loading. (The steps of loading are outlined in the HA docs)
