Aeotec trisensor
Good morning,
I recently bought the aeotec controller ZW090 Z-Stick Gen5 EU and aeotec ZWA005 TriSensor I’m having problems with the configuration so my homeassistant does not recognize the tri sensor that is displayed as unknown_id005.
I tried to recompile the openzwave libraries from the sources now home assistant sees the tri sensor but the values ​​are not updated and always remains in Initialization (CacheLoad).
can you help me?
Did you got it resolved? I have exactly same situation…
I was able to solve the problem by updating openzwave and adding devices from the homeassistant interface and not directly with the button on the usb key.
Try the following Need configuration advice for Aeotec Trisensor ZWA005
