Has anyone else experienced this or know of a way to correct it? This used to work just fine but in the past few ZWave-JS updates it seems to have stopped updating. Currently it’s stuck at 0%.
Yes, I have the same problem. Also looking for a solution.
Same problem here. I have 3 Aeotec WallMote Quad units at home. The battery levels for all of them got stuck. I’ve tried the “REFRESH” button for the “Battery v1” value, nothing happened.
My 1st unit’s battery level is stuck at 0% (low battery level triggered). I fully recharged it. The battery level doesn’t update.
My 2nd unit’s battery level is stuck at 84%.
My 3rd unit’s battery level is stuck at 88%.
Computer:
Raspberry Pi 4 Model B
Add-on & OS:
zwave-js-ui: 8.8.3
zwave-js: 10.5.5
Home Assistant 2023.2.4
Supervisor 2023.01.1
Operating System 9.5
Frontend 20230202.0
Z-Wave Controller:
Aeotec Z-Stick 7
700 Series-based Controller
Product code: ZST10-700
FW: v7.17.2
SDK: v7.17.2
Z-Wave Device:
FW: v2.3
(All of them are up-to-date at the time I publish this post - Feb 13, 2023)
I am not sure if this was caused by any of the ZWave-JS updates.
For me, it also looks like it’s triggered by a WallMote Quad unit’s battery level reaching 0%. Right after the first time I let any of my WallMotes reach 0%, this problem occurred. Once it occurred, ZWave-JS stops updating battery levels for all the WallMote Quad units.
Same here! It used to update in the past…
Now after charge it does not, also not after manual wake…
Same here. Has anyone found a solution for this issue yet?
