I’m having issues with the above mentioned sensor. The water detection portion works perfectly however the temperature and humidity do not update ever and only display the readings it had when first paired to the zwave network. I have tried removing then adding it back, checking the configuration and resetting the device. I’ve submitted a ticket with aeotec but wanted to see if anyone had similar issues with this device or other zwave devices similar to this. To me it seems like a fault with the device but I can’t rule out Home Assistant…
Edit-
Wanted to add in that I’m using the z-waveJS integration and addon
The sensor is the ZWA019
I just picked up this sensor and I can’t even get that far. It’s not recognised on my zwaveJS system despite being in the database. Was yours easily picked up?
It picked it up immediately. Something I noticed with aeotec battery sensors is when it’s adding in zwavejs you have to hit the action button every couple seconds to wake it up to finish the add process, otherwise it won’t add correctly.
Did you sort this out okay? The sensor is not officially in the Zwave-JS database, but it does detect and all the functions do work using generic detection. ( I have a couple of them)
It did take two or three attempts though, but I think that is just because the pairing process is very particular on the sensor itself and I didn’t get it right first couple of tries lol
