I have a Aeotec Z-Stick 7 that i use to use with a raspberry pi after a hardware malfunction with the pi, I have now moved over to hyper-v is there away of runing the z wave stick on a raspberry pi now and pass this over the nextwork to the hyper-v
Install zwavejs2mqtt on the pi, and point the zwave-js integration to that instance.
Do I just need to install zwavejs2mqtt on the pi useing there Raspberry Pi OS, how do I then point the zwave addon to the pi over the network? the only device options that I get is the local serial ones
The zwavejs2mqtt on your Pi replaces the zwave add-on. You don’t use the add-on anymore, and point the zwavejs integration to your pi.
I have installed Z wave onto the pi, but seem to be having issues pointing HA to the pi every time that I add the integration and point the address to the host of the pi, it says failed to connect. any ideas?
