Background
I have a Aeotec Z Stick 7 with the latest and hopefully greatest firmware 7.19.3.
It is connected to a USB2 port through an extension cable and it works fairly well. During my firmware upgrade attempts (prior to discovering the wonders of Z-Wave JS though HA) I think I messed up the power levels.
My current settings
Found inZ-Wave JS/Control Panel/Device (select the Z-Stick)
I have selected Europe as RF region and the current power levels are set to:
Normal Power Level 0.0 dBm
Measured Power Level 3.3dBm
These are the suggested numbers from the hint in the blue box. I reduced normal Power level from 9.9dBm.
It works but keep loosing a node in the basement ==> it would be nice to at least have the correct settings.
Question
Could anyone please tell me what the power levels should be for Europe?
Thanks!
