So i had a powercut a few days ago that has wiped out my zwave network. Having looked at HA logs i see that it couldn’t connect to the network (all my devices are missing here).
So i fired up OZWCP and this is the output i’m getting. HA is stopped and i haven’t changed anything from the working config. Any ideas?
2017-05-28 09:53:48.772 Always, OpenZwave Version 1.4.2315 Starting Up
webserver starting port 8124
post: key=dev data=/dev/ttyACM0 size=12
post: key=fn data=open size=4
post: key=usb data=false size=5
2017-05-28 09:53:58.489 Info, Setting Up Provided Network Key for Secure Communications
2017-05-28 09:53:58.489 Warning, Failed - Network Key Not Set
2017-05-28 09:53:58.489 Info, mgr, Added driver for controller /dev/ttyACM0
2017-05-28 09:53:58.489 Info, Opening controller /dev/ttyACM0
2017-05-28 09:53:58.489 Info, Trying to open serial port /dev/ttyACM0 (attempt 1)
2017-05-28 09:53:58.489 Error, ERROR: Cannot get exclusive lock for serial port /dev/ttyACM0. Error code 11
2017-05-28 09:53:58.489 Info, Serial port /dev/ttyACM0 opened (attempt 1)
2017-05-28 09:53:58.489 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_GET_VERSION: 0x01, 0x03, 0x00, 0x15, 0xe9
2017-05-28 09:53:58.489 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_MEMORY_GET_ID: 0x01, 0x03, 0x00, 0x20, 0xdc
2017-05-28 09:53:58.489 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_GET_CONTROLLER_CAPABILITIES: 0x01, 0x03, 0x00, 0x05, 0xf9
2017-05-28 09:53:58.489 Detail, contrlr, Queuing (Command) FUNC_ID_SERIAL_API_GET_CAPABILITIES: 0x01, 0x03, 0x00, 0x07, 0xfb
2017-05-28 09:53:58.489 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_GET_SUC_NODE_ID: 0x01, 0x03, 0x00, 0x56, 0xaa
2017-05-28 09:53:58.489 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x15) - FUNC_ID_ZW_GET_VERSION: 0x01, 0x03, 0x00, 0x15, 0xe9
2017-05-28 09:53:58.491 Detail, contrlr, Received: 0x01, 0x10, 0x01, 0x15, 0x5a, 0x2d, 0x57, 0x61, 0x76, 0x65, 0x20, 0x33, 0x2e, 0x39, 0x35, 0x00, 0x01, 0x99
2017-05-28 09:53:58.491 Info, contrlr, Received reply to FUNC_ID_ZW_GET_VERSION:
2017-05-28 09:53:58.491 Info, contrlr, Static Controller library, version Z-Wave 3.95
2017-05-28 09:53:58.491 Detail, Node045, Expected reply was received
2017-05-28 09:53:58.491 Detail, Node045, Message transaction complete
2017-05-28 09:53:58.491 Detail, contrlr, Removing current message
2017-05-28 09:53:58.491 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x20) - FUNC_ID_ZW_MEMORY_GET_ID: 0x01, 0x03, 0x00, 0x20, 0xdc
2017-05-28 09:53:58.493 Warning, WARNING: Out of frame flow! (0x20). Sending NAK.
2017-05-28 09:53:58.493 Warning, WARNING: Out of frame flow! (0x8e). Sending NAK.
2017-05-28 09:53:58.494 Warning, WARNING: Out of frame flow! (0xbe). Sending NAK.
2017-05-28 09:53:58.496 Detail, contrlr, Received: 0x01, 0x08, 0x01, 0x20, 0xed, 0xbe, 0x0b, 0x8e, 0x01, 0x20
2017-05-28 09:53:58.496 Warning, contrlr, WARNING: Checksum incorrect - sending NAK
2017-05-28 09:53:58.496 Warning, WARNING: Out of frame flow! (0xbe). Sending NAK.
2017-05-28 09:54:08.492 Error, contrlr, ERROR: Dropping command, expected response not received after 1 attempt(s)
2017-05-28 09:54:08.492 Detail, contrlr, Removing current message
2017-05-28 09:54:08.492 Detail, contrlr, Notification: Notification - TimeOut
2017-05-28 09:54:08.492 Info, Notification: Notification home 00000000 node 255 Timeout
2017-05-28 09:54:08.492 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x05) - FUNC_ID_ZW_GET_CONTROLLER_CAPABILITIES: 0x01, 0x03, 0x00, 0x05, 0xf9
2017-05-28 09:54:08.493 Detail, contrlr, Received: 0x01, 0x04, 0x01, 0x05, 0x08, 0xf7
2017-05-28 09:54:08.493 Info, contrlr, Received reply to FUNC_ID_ZW_GET_CONTROLLER_CAPABILITIES:
2017-05-28 09:54:08.493 Info, contrlr, There is no SUC ID Server (SIS) in this network.
2017-05-28 09:54:08.493 Info, contrlr, The PC controller is a primary controller.
2017-05-28 09:54:08.493 Detail, Node247, Expected reply was received
2017-05-28 09:54:08.493 Detail, Node247, Message transaction complete
2017-05-28 09:54:08.493 Detail, contrlr, Removing current message
2017-05-28 09:54:08.493 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x07) - FUNC_ID_SERIAL_API_GET_CAPABILITIES: 0x01, 0x03, 0x00, 0x07, 0xfb
2017-05-28 09:54:08.501 Detail, contrlr, Received: 0x01, 0x2b, 0x01, 0x07, 0x01, 0x00, 0x00, 0xff, 0x88, 0x4f, 0x00, 0xfb, 0x9f, 0x7d, 0x00, 0x80, 0x86, 0xe8, 0x73, 0x00, 0x60, 0x00, 0xfb, 0x01, 0x07, 0x01, 0x86, 0x5a, 0xfe, 0x88, 0x4f, 0x1f, 0xfb, 0x9f, 0x67, 0x00, 0x80, 0x00, 0x00, 0x00, 0x0e, 0x60, 0x01, 0x2b, 0x81
2017-05-28 09:54:08.501 Warning, contrlr, WARNING: Checksum incorrect - sending NAK
2017-05-28 09:54:08.502 Warning, WARNING: Out of frame flow! (0x00). Sending NAK
