Aeotec Z-Stick Gen 5
Yes, please, please post back what you find and how it goes. At this point I am dead in the water more or less until I can figure out what is going on.
I wonā€™t be able to start until this evening, but my Dakboard is running on the NOOBS OS, which is what at least installed the first few steps of HASS without issue. Although this was with the manual install.
I might try and install the rest of the manual steps later to see how it goes on that OS but will likely start with the AIO on the Raspbian image from here:
I might start with the NOOBS first but weā€™ll see.
Iā€™ll be sure to update.
I see that the Raspbian Jessie is what you were trying, but Iā€™ll still report back with my revelations.
If your attempting to use the AIO installer on theRaspberry Pi 3, you may be seeing a known issue and should try this :slight_smile: it fixed the installer for me on the latest Pixel release
Once its installed you need to fix mosquito in configuration.yaml before Home Assistant will boot :smiley:
Currently trying this on an RPi B+ I believe it is.
Thank you sir, very much appreciated. I will start over again and see how it all goes.
So I reinstalled everything using the AIO and steps given in the thread linked to by @noodlemctwoodle and after commenting out the mqtt broker information, HA worked. Though I have yet to try the Open ZWave yet, but at least HA works and it auto starts on boot up.
@StormStrikes Iā€™ve yet to receive my zwave kit, Iā€™m hoping santa will bring me some aeon labs Gen5 sensors and the Gen5 USB stick. So if you find any issues please share as Iā€™m just getting started on Home Assistant too :smile:
@noodlemctwoodle I will do so. If I recall when I had HA set up before and experimenting with it, I didnā€™t have too many issues with the devices themselves, small stuff mostly that did not really affect overall functionality.
But now that HA supports reading from a Vera hub, which I have, I will pull in my devices from that and see how it all goes and see if there are any functionality issues and report back.
Do you have the two files generated by OZWCP in your .homeassistant directory, named something like zwcfg_0x12345678.xml and zwscene.xml?
Yes sir, I do.
Does your config_path directory have stuff in it? Mine looks like this:
drwxr-xr-x 2 hass nogroup     6 Sep 16 23:22 2gig
drwxr-xr-x 2 hass nogroup    14 Sep 16 23:22 BeNext
drwxr-xr-x 2 hass nogroup     9 Sep 16 23:22 act
drwxr-xr-x 2 hass nogroup    46 Sep 16 23:22 aeotec
drwxr-xr-x 2 hass nogroup     4 Sep 16 23:22 assa_abloy
drwxr-xr-x 2 hass nogroup     4 Sep 16 23:22 cooper
drwxr-xr-x 2 hass nogroup     5 Sep 16 23:22 danfoss
-rw-r--r-- 1 hass nogroup 19463 Sep 16 23:22 device_classes.xml
-rw-r--r-- 1 hass nogroup  2847 Sep 16 23:22 device_classes.xsd
-rw-r--r-- 1 hass nogroup 11423 Sep 16 23:22 device_configuration.xsd
drwxr-xr-x 2 hass nogroup     3 Sep 16 23:22 devolo
drwxr-xr-x 2 hass nogroup     5 Sep 16 23:22 dlink
drwxr-xr-x 2 hass nogroup     4 Sep 16 23:22 domitech
drwxr-xr-x 2 hass nogroup     3 Sep 16 23:22 dragontech
drwxr-xr-x 2 hass nogroup     6 Sep 16 23:22 duwi
drwxr-xr-x 2 hass nogroup     3 Sep 16 23:22 electronicsolutions
drwxr-xr-x 2 hass nogroup     8 Sep 16 23:22 enerwave
drwxr-xr-x 2 hass nogroup     4 Sep 16 23:22 eurotronic
drwxr-xr-x 2 hass nogroup    20 Sep 16 23:22 everspring
drwxr-xr-x 2 hass nogroup     3 Sep 16 23:22 everspringct
drwxr-xr-x 2 hass nogroup     5 Sep 16 23:22 evolve
drwxr-xr-x 2 hass nogroup     4 Sep 16 23:22 fakro
drwxr-xr-x 2 hass nogroup    24 Sep 16 23:22 fibaro
drwxr-xr-x 2 hass nogroup     6 Sep 16 23:22 fortrezz
drwxr-xr-x 2 hass nogroup     3 Sep 16 23:22 frostdale
drwxr-xr-x 2 hass nogroup     7 Sep 16 23:22 ge
drwxr-xr-x 2 hass nogroup     4 Sep 16 23:22 gr
drwxr-xr-x 2 hass nogroup     4 Sep 16 23:22 greenwave
drwxr-xr-x 2 hass nogroup     6 Sep 16 23:22 homeseer
drwxr-xr-x 2 hass nogroup     3 Sep 16 23:22 honeywell
drwxr-xr-x 2 hass nogroup     9 Sep 16 23:22 horstmann
drwxr-xr-x 2 hass nogroup     3 Sep 16 23:22 intermatic
drwxr-xr-x 2 hass nogroup     3 Sep 16 23:22 iris
drwxr-xr-x 2 hass nogroup     3 Sep 16 23:22 kwikset
drwxr-xr-x 2 hass nogroup     7 Sep 16 23:22 leviton
drwxr-xr-x 2 hass nogroup     5 Sep 16 23:22 linear
-rw-r--r-- 1 hass nogroup 66221 Sep 16 23:22 manufacturer_specific.xml
-rw-r--r-- 1 hass nogroup  1166 Sep 16 23:22 manufacturer_specific.xsd
drwxr-xr-x 2 hass nogroup     9 Sep 16 23:22 mcohome
drwxr-xr-x 2 hass nogroup     4 Sep 16 23:22 merten
drwxr-xr-x 2 hass nogroup     3 Sep 16 23:22 nexia
drwxr-xr-x 2 hass nogroup     7 Sep 16 23:22 nodon
drwxr-xr-x 2 hass nogroup     5 Sep 16 23:22 northq
-rw-r--r-- 1 hass nogroup  1255 Sep 17 15:04 options.xml
-rw-r--r-- 1 hass nogroup   642 Sep 16 23:22 options.xsd
drwxr-xr-x 2 hass nogroup    14 Sep 16 23:22 philio
drwxr-xr-x 2 hass nogroup     5 Sep 16 23:22 polycontrol
drwxr-xr-x 2 hass nogroup    10 Sep 16 23:22 popp
drwxr-xr-x 2 hass nogroup     4 Sep 16 23:22 qees
drwxr-xr-x 2 hass nogroup    22 Sep 16 23:22 qubino
drwxr-xr-x 2 hass nogroup     7 Sep 16 23:22 rcs
drwxr-xr-x 2 hass nogroup     7 Sep 16 23:22 remotec
drwxr-xr-x 2 hass nogroup     3 Sep 16 23:22 schlage
drwxr-xr-x 2 hass nogroup     4 Sep 16 23:22 schlagelink
drwxr-xr-x 2 hass nogroup     3 Sep 16 23:22 sensative
drwxr-xr-x 2 hass nogroup     5 Sep 16 23:22 shenzen_neo
drwxr-xr-x 2 hass nogroup     3 Sep 16 23:22 stelpro
drwxr-xr-x 2 hass nogroup     4 Sep 16 23:22 swiid
drwxr-xr-x 2 hass nogroup     3 Sep 16 23:22 thermofloor
drwxr-xr-x 2 hass nogroup     4 Sep 16 23:22 trane
drwxr-xr-x 2 hass nogroup    12 Sep 16 23:22 vision
drwxr-xr-x 2 hass nogroup     3 Sep 16 23:22 vitrum
drwxr-xr-x 2 hass nogroup     3 Sep 16 23:22 waynedalton
drwxr-xr-x 2 hass nogroup    11 Sep 16 23:22 wenzhou
drwxr-xr-x 2 hass nogroup     5 Sep 16 23:22 widom
drwxr-xr-x 2 hass nogroup     4 Sep 16 23:22 zipato
drwxr-xr-x 2 hass nogroup    16 Sep 16 23:22 zwave.me
-rw-r--r-- 1 hass nogroup  8707 Sep 16 23:22 zwcfg.xsd
-rw-r--r-- 1 hass nogroup  1037 Sep 16 23:22 zwscene.xsd
Any update here, did any of you guys manage to solve it? Have the same issueā€¦
Edit: ended up running the AIO setup and itā€™s working.
Hello Sebastian,
I installed Home Assistant with Docker Imageā€¦
I try the ā€œpython -m homeassistant --config /config --script check_configā€
and return : ā€œ/usr/local/bin/python: No module named homeassistantā€
Could you say me why ?
I try to install the Aeotec Z-Stick Gen 5 too
Thank you !
From outside the docker container, I use this:
docker exec -ti hass python -m homeassistant --config /config --script check_config
(this is assuming your container name is hass - otherwise change it to ... exec-ti <your_container_name> ...)
Sebastian
I retry and :
Testing configuration at /config
17-05-04 12:55:48 INFO (MainThread) [homeassistant.setup] Setting up introduction
17-05-04 12:55:49 INFO (MainThread) [homeassistant.setup] Setting up http
17-05-04 12:55:49 INFO (MainThread) [homeassistant.setup] Setting up recorder
17-05-04 12:55:49 INFO (MainThread) [homeassistant.setup] Setting up api
17-05-04 12:55:49 INFO (MainThread) [homeassistant.setup] Setting up websocket_api
17-05-04 12:55:49 INFO (MainThread) [homeassistant.setup] Setting up history
17-05-04 12:55:49 INFO (MainThread) [homeassistant.setup] Setting up frontend
17-05-04 12:55:49 INFO (MainThread) [homeassistant.setup] Setting up sun
17-05-04 12:55:49 INFO (MainThread) [homeassistant.setup] Setting up conversation
17-05-04 12:55:49 INFO (MainThread) [homeassistant.setup] Setting up sensor
17-05-04 12:55:49 INFO (MainThread) [homeassistant.setup] Setting up group
17-05-04 12:55:49 INFO (MainThread) [homeassistant.setup] Setting up discovery
17-05-04 12:55:49 INFO (MainThread) [homeassistant.setup] Setting up zwave
17-05-04 12:55:49 INFO (MainThread) [homeassistant.setup] Setting up updater
17-05-04 12:55:49 INFO (MainThread) [homeassistant.setup] Setting up config
17-05-04 12:55:49 INFO (MainThread) [homeassistant.setup] Setting up tts
17-05-04 12:55:49 INFO (MainThread) [homeassistant.setup] Setting up logbook
I new and canā€™t add Replyā€¦
Thank you sebk-666
USB Stick is well at /dev/ttyACM0
but other parameters (config_path, polling and autoheal), where can i find values ?
I try with your config but donā€™t work
Thank you
The config check only checks the configuration for correct syntax.
You can still have a syntactically correct, but wrong configuration.
What does your zwave config look like?
Mine is:
zwave:
  usb_path: /dev/ttyACM0
  config_path: /usr/src/app/build/python-openzwave/openzwave/config/
  polling_interval: 60000
  autoheal: true
When starting the container, you have to enable access to the zwave stick by specifying the device on the command line with docker run ... --device=/dev/ttyACM0 ... (your device may have a different name).
Sebastian
