Hi.
First post here after having installed Home Assistant last week and it’s just great. However I have run into a problem with my Aeotec Z-Stick Gen5 and Z-Wave JS/Z-Wave JS to MQTT that I simply can’t solve. So I hope someone here can help me out.
My setup:
HP Prodesk 400 G2, i7, 16 GB RAM, 256 GB SDD
Windows 10 Pro and VirtualBox with Home Assistant setup and running
USB 2.0 OHCI + ECHI controller setup with the Z-Stick 5 added to the USB list (disappears from Windows when VirtualBox is started).
Aeotec Z-Stick Gen5 connected to an USB 2.0 port with a short USB extension lead. It’s fresh out of the box and has been reset. No Windows drivers have been added.
I have setup Z-Wave JS MQTT first, with a network key and I can see the Z-Stick in there. After that I added the Z-Wave JS addon, and told it not to be used as the supervisor, and added the ws: link to Z-Wave JS to MQTT in there.
What I have a problem with is that it is not secure, so I cannot add my doorlock via Secure inclusion.
The error I’m getting in the Z-Wave JS log is:
19:00:07.787 DRIVER version 6.6.3
19:00:07.788 DRIVER
19:00:07.830 DRIVER serial port errored: Error Resource temporarily unavailable Cannot lock port
Unable to start driver [Error: Error Resource temporarily unavailable Cannot lock port]
[19:00:08] INFO: Successfully send discovery information to Home Assistant.
Is this because Z-Wave JS to MQTT is controlling it, and I shouldn’t be worried?
And the log from Z-Wave JS to MQTT is:
17:50:19.060 CNTRLR finding SUC...
17:50:19.064 SERIAL » 0x01030056aa (5 bytes)
17:50:19.064 DRIVER » [REQ] [GetSUCNodeId]
17:50:19.069 SERIAL « [ACK] (0x06)
17:50:19.071 SERIAL « 0x0104015600ac (6 bytes)
17:50:19.072 SERIAL » [ACK] (0x06)
17:50:19.074 DRIVER « [RES] [GetSUCNodeId]
payload: 0x00
17:50:19.076 CNTRLR no SUC present
17:50:19.093 CNTRLR querying node information...
17:50:19.096 SERIAL » 0x01030002fe (5 bytes)
17:50:19.096 DRIVER » [REQ] [GetSerialApiInitData]
17:50:19.101 SERIAL « [ACK] (0x06)
17:50:19.201 SERIAL « 0x0125010205001d010000000000000000000000000000000000000000000000000 (39 bytes)
00000000500c5
17:50:19.202 SERIAL » [ACK] (0x06)
17:50:19.203 DRIVER « [RES] [GetSerialApiInitData]
payload: 0x05001d01000000000000000000000000000000000000000000000000000000000
500
17:50:19.205 CNTRLR received node information:
controller role: primary
controller is a SUC: false
controller is a slave: false
controller supports timers: false
nodes in the network: 1
17:50:19.213 DRIVER Cache file for homeId 0xe514ac8e found, attempting to restore the network from
cache...
17:50:19.219 CNTRLR [Node 001] trying to load device config
17:50:19.225 CNTRLR [Node 001] device config loaded
17:50:19.225 DRIVER Restoring the network from cache was successful!
17:50:19.226 CNTRLR [Node 001] [Manufacturer Specific] manufacturerId: metadata updated
17:50:19.226 CNTRLR [Node 001] [Manufacturer Specific] productType: metadata updated
17:50:19.227 CNTRLR [Node 001] [Manufacturer Specific] productId: metadata updated
17:50:19.227 CNTRLR [Node 001] [~] [Manufacturer Specific] manufacturerId: 134 => 134
17:50:19.228 CNTRLR [Node 001] [~] [Manufacturer Specific] productType: 1 => 1
17:50:19.228 CNTRLR [Node 001] [~] [Manufacturer Specific] productId: 90 => 90
17:50:19.228 CNTRLR setting serial API timeouts: ack = 1000 ms, byte = 150 ms
17:50:19.231 SERIAL » 0x01050006640f97 (7 bytes)
17:50:19.231 DRIVER » [REQ] [SetSerialApiTimeouts]
payload: 0x640f
17:50:19.236 SERIAL « [ACK] (0x06)
17:50:19.238 SERIAL « 0x01050106640f96 (7 bytes)
17:50:19.238 SERIAL » [ACK] (0x06)
17:50:19.239 DRIVER « [RES] [SetSerialApiTimeouts]
payload: 0x640f
17:50:19.241 CNTRLR serial API timeouts overwritten. The old values were: ack = 1000 ms, byte = 15
0 ms
17:50:19.241 CNTRLR Interview completed
17:50:19.242 DRIVER driver ready
2021-03-24 17:50:19.242 INFO ZWAVE: Zwave driver is ready
2021-03-24 17:50:19.242 INFO ZWAVE: Controller status: Driver ready
2021-03-24 17:50:19.244 INFO ZWAVE: Scanning network with homeid: 0xe514ac8e
17:50:19.244 CNTRLR [Node 001] Beginning interview - last completed stage: RestartFromCache
17:50:19.245 CNTRLR [Node 001] not pinging the controller
2021-03-24 17:50:19.245 INFO ZWAVE-SERVER: ZwaveJS server listening on port 3000
17:50:19.247 CNTRLR [Node 001] Interview stage completed: CommandClasses
17:50:19.248 CNTRLR [Node 001] trying to load device config
17:50:19.255 CNTRLR [Node 001] device config loaded
17:50:19.256 CNTRLR [Node 001] Interview stage completed: OverwriteConfig
17:50:19.256 CNTRLR » [Node 001] requesting node neighbors...
17:50:19.259 SERIAL » 0x010700800100000079 (9 bytes)
17:50:19.259 DRIVER » [Node 001] [REQ] [GetRoutingInfo]
remove non-repeaters: false
remove bad links: false
17:50:19.263 SERIAL « [ACK] (0x06)
17:50:19.268 SERIAL « 0x01200180000000000000000000000000000000000000000000000000000000000 (34 bytes)
05e
17:50:19.269 SERIAL » [ACK] (0x06)
17:50:19.270 DRIVER « [RES] [GetRoutingInfo]
node ids:
2021-03-24 17:50:19.272 INFO ZWAVE: Node 1 is alive
17:50:19.272 CNTRLR [Node 001] The node is alive.
2021-03-24 17:50:19.273 WARN ZWAVE: Node 1 doesn't support groups associations
2021-03-24 17:50:19.274 INFO ZWAVE: Node 1 ready: AEON Labs - ZW090 (Z‐Stick Gen5 USB Controller)
17:50:19.274 CNTRLR [Node 001] The node is ready to be used
17:50:19.274 CNTRLR All nodes are ready to be used
2021-03-24 17:50:19.274 INFO ZWAVE: Controller status: Scan completed
2021-03-24 17:50:19.274 INFO ZWAVE: Network scan complete. Found: 1 nodes
17:50:19.274 CNTRLR « [Node 001] node neighbors received:
17:50:19.275 CNTRLR [Node 001] Interview stage completed: Neighbors
17:50:19.275 CNTRLR [Node 001] Interview completed
2021-03-24 17:50:19.275 INFO ZWAVE: Node 1: interview completed, all values are updated
2021-03-24 17:51:56.682 INFO APP: GET / 304 0.915 ms - -
2021-03-24 17:51:56.713 INFO APP: GET /static/css/app.3e2ca6ecff8b60f8b9e5.css 304 0.710 ms - -
2021-03-24 17:51:56.718 INFO APP: GET /static/js/app.7cd976cb167718e60e4d.js 304 0.446 ms - -
2021-03-24 17:51:57.019 INFO APP: GET /api/auth-enabled 304 2.405 ms - -
2021-03-24 17:51:57.169 INFO APP: GET /static/logo.png 304 0.455 ms - -
2021-03-24 17:51:57.204 INFO APP: GET /static/fonts/MaterialIcons-Regular.fa3334f.woff2 304 0.642 ms - -
[session-file-store] Deleting expired sessions
2021-03-24 19:02:32.716 INFO APP: GET / 304 0.610 ms - -
2021-03-24 19:02:32.736 INFO APP: GET /static/css/app.3e2ca6ecff8b60f8b9e5.css 304 0.587 ms - -
2021-03-24 19:02:32.741 INFO APP: GET /static/js/app.7cd976cb167718e60e4d.js 304 0.603 ms - -
2021-03-24 19:02:33.023 INFO APP: GET /api/auth-enabled 304 2.091 ms - -
2021-03-24 19:02:33.186 INFO APP: GET /static/logo.png 304 0.410 ms - -
2021-03-24 19:02:33.211 INFO APP: GET /static/fonts/MaterialIcons-Regular.fa3334f.woff2 304 0.467 ms - -
2021-03-24 19:02:34.532 INFO APP: GET /api/settings 200 37.464 ms - 814
2021-03-24 19:02:34.634 INFO APP: GET /api/auth-enabled 304 1.930 ms - -
And in Z-Wave to MQTT I see the Z-Stick Gen5 fine, but secured says ‘No’ and I do have a randomly generated network key setup under Settings -> Z-wave, together with the serial port /dev/ttyACM0
In Z-Wave JS the device is slightly different: /dev/serial/by-id/usb-0658_0200-if00 and the network key is the same as in Z-Wave to MQTT.
So, does anyone have an idea as to why I cannot secure the Z-Stick Gen5?
Thanks!
/ Michael Englyst
