trying to update my z wave controller’s firmware from 7.20.x to 7.21.4 as specified in 700 series Controller Firmware Updates (Linux) · kpine/zwave-js-server-docker Wiki · GitHub.
tried firmware otw from z.wave js ui… it failed.
entering in bootloader mode and retrying is stuck at 0%
next move is to try the terminal flash utility?
“ Be sure to stop any other Z-Wave JS applications prior to running the above. Otherwise, the update can fail and the controller will be hung at the bootloader.”
the question is… what should I need to stop prior to perform the terminal flashing procedure?
Have you any further suggestion?
Any help really appreciated…
