2020-10-11 21:09:39.608 Detail, Node003, Refreshed Value: old value=false, new value=false, type=bool
2020-10-11 21:09:39.608 Detail, Node003, Changes to this value are not verified
2020-10-11 21:09:39.608 Info, Node003, Received Meter report from node 3: Energy=0.000kWh
2020-10-11 21:09:39.608 Detail, Node003, Refreshed Value: old value=0.000, new value=0.000, type=decimal
2020-10-11 21:09:39.609 Info, Node003, Previous value was 0.000kWh, received 120 seconds ago.
2020-10-11 21:09:39.609 Detail, Node003, Refreshed Value: old value=0.000, new value=0.000, type=decimal
2020-10-11 21:09:39.609 Detail, Node003, Changes to this value are not verified
2020-10-11 21:09:39.609 Detail, Node003, Refreshed Value: old value=120, new value=120, type=int
2020-10-11 21:09:39.609 Detail, Node003, Notification: ValueChanged
2020-10-11 21:09:39.613 Detail, Node003, Notification: ValueChanged
2020-10-11 21:09:39.617 Detail, Node003, Notification: ValueChanged
2020-10-11 21:09:39.622 Detail, Node003, Notification: ValueChanged
2020-10-11 21:09:39.708 Detail, Node003, Received: 0x01, 0x1c, 0x00, 0x04, 0x00, 0x03, 0x16, 0x56, 0x01, 0x60, 0x0d, 0x02, 0x00, 0x32, 0x02, 0x21, 0x64, 0x00, 0x00, 0x00, 0x00, 0x00, 0x78, 0x00, 0x00, 0x00, 0x00, 0x5a, 0xc6, 0x5b
2020-10-11 21:09:39.708 Info, Node003, Received CRC16-command from node 3
2020-10-11 21:09:39.708 Info, Node003, Received a MultiChannelEncap from node 3, endpoint 2 for Command Class COMMAND_CLASS_METER
2020-10-11 21:09:39.708 Detail, Node003, Refreshed Value: old value=false, new value=false, type=bool
2020-10-11 21:09:39.708 Detail, Node003, Changes to this value are not verified
2020-10-11 21:09:39.709 Info, Node003, Received Meter report from node 3: Energy=0.000kWh
2020-10-11 21:09:39.709 Detail, Node003, Refreshed Value: old value=0.000, new value=0.000, type=decimal
2020-10-11 21:09:39.709 Detail, Node003, Changes to this value are not verified
2020-10-11 21:09:39.709 Info, Node003, Previous value was 0.000kWh, received 120 seconds ago.
2020-10-11 21:09:39.709 Detail, Node003, Refreshed Value: old value=120, new value=120, type=int
2020-10-11 21:09:39.709 Detail, Node003, Notification: ValueChanged
2020-10-11 21:09:39.719 Detail, Node003, Notification: ValueChanged
2020-10-11 21:09:39.727 Detail, Node003, Notification: ValueChanged
2020-10-11 21:09:39.738 Detail, Node003, Notification: ValueChanged
2020-10-11 21:09:39.807 Detail, Node003, Received: 0x01, 0x19, 0x00, 0x04, 0x00, 0x03, 0x13, 0x56, 0x01, 0x32, 0x02, 0xa1, 0x7c, 0x00, 0x00, 0x00, 0x00, 0x00, 0x78, 0x00, 0x00, 0x00, 0x00, 0x01, 0x60, 0x11, 0x40
2020-10-11 21:09:39.807 Info, Node003, Received CRC16-command from node 3
2020-10-11 21:09:39.808 Detail, Node003, Refreshed Value: old value=false, new value=false, type=bool
2020-10-11 21:09:39.808 Detail, Node003, Changes to this value are not verified
2020-10-11 21:09:39.808 Info, Node003, Received Meter report from node 3: Unknown=0.000
2020-10-11 21:09:39.808 Detail, Node003, Refreshed Value: old value=0.000, new value=0.000, type=decimal
2020-10-11 21:09:39.808 Info, Node003, Previous value was 0.000, received 120 seconds ago.
2020-10-11 21:09:39.808 Detail, Node003, Refreshed Value: old value=120, new value=120, type=int
2020-10-11 21:09:39.809 Detail, Node003, Notification: ValueChanged
2020-10-11 21:09:39.818 Detail, Node003, Notification: ValueChanged
2020-10-11 21:09:39.828 Detail, Node003, Notification: ValueChanged
2020-10-11 21:09:39.839 Detail, Node003, Notification: ValueChanged
2020-10-11 21:09:49.106 Detail, Node003, Received: 0x01, 0x18, 0x00, 0x04, 0x00, 0x03, 0x12, 0x56, 0x01, 0x32, 0x02, 0xa1, 0x6c, 0x00, 0x00, 0x00, 0x00, 0x00, 0x14, 0x00, 0x00, 0x00, 0x00, 0xf4, 0xbc, 0x04
2020-10-11 21:09:49.107 Detail,
2020-10-11 21:09:49.107 Info, Node003, Received CRC16-command from node 3
2020-10-11 21:09:49.107 Detail, Node003, Refreshed Value: old value=false, new value=false, type=bool
2020-10-11 21:09:49.107 Detail, Node003, Changes to this value are not verified
2020-10-11 21:09:49.107 Info, Node003, Received Meter report from node 3: Current=0.000A
2020-10-11 21:09:49.107 Detail, Node003, Refreshed Value: old value=0.000, new value=0.000, type=decimal
2020-10-11 21:09:49.107 Info, Node003, Previous value was 0.000A, received 20 seconds ago.
2020-10-11 21:09:49.108 Detail, Node003, Changes to this value are not verified
2020-10-11 21:09:49.108 Detail, Node003, Refreshed Value: old value=20, new value=20, type=int
2020-10-11 21:09:49.108 Detail, Node003, Notification: ValueChanged
2020-10-11 21:09:49.118 Detail, Node003, Notification: ValueChanged
2020-10-11 21:09:49.130 Detail, Node003, Notification: ValueChanged
2020-10-11 21:09:49.134 Detail, Node003, Notification: ValueChanged
2020-10-11 21:09:49.206 Detail, Node003, Received: 0x01, 0x18, 0x00, 0x04, 0x00, 0x03, 0x12, 0x56, 0x01, 0x32, 0x02, 0x21, 0x74, 0x00, 0x00, 0x00, 0x00, 0x00, 0x14, 0x00, 0x00, 0x00, 0x00, 0xa9, 0xae, 0xd3
2020-10-11 21:09:49.207 Detail,
2020-10-11 21:09:49.207 Info, Node003, Received CRC16-command from node 3
2020-10-11 21:09:49.207 Detail, Node003, Refreshed Value: old value=false, new value=false, type=bool
2020-10-11 21:09:49.207 Detail, Node003, Changes to this value are not verified
2020-10-11 21:09:49.207 Info, Node003, Received Meter report from node 3: Power=0.000W
2020-10-11 21:09:49.207 Detail, Node003, Refreshed Value: old value=0.000, new value=0.000, type=decimal
2020-10-11 21:09:49.207 Info, Node003, Previous value was 0.000W, received 20 seconds ago.
2020-10-11 21:09:49.208 Detail, Node003, Changes to this value are not verified
2020-10-11 21:09:49.208 Detail, Node003, Refreshed Value: old value=20, new value=20, type=int
2020-10-11 21:09:49.208 Detail, Node003, Notification: ValueChanged
2020-10-11 21:09:49.218 Detail, Node003, Notification: ValueChanged
2020-10-11 21:09:49.228 Detail, Node003, Notification: ValueChanged
2020-10-11 21:09:49.233 Detail, Node003, Notification: ValueChanged
2020-10-11 21:09:49.307 Detail, Node003, Received: 0x01, 0x18, 0x00, 0x04, 0x00, 0x03, 0x12, 0x56, 0x01, 0x32, 0x02, 0x21, 0x64, 0x00, 0x00, 0x00, 0x00, 0x00, 0x14, 0x00, 0x00, 0x00, 0x00, 0xfc, 0x93, 0xab
2020-10-11 21:09:49.307 Info, Node003, Received CRC16-command from node 3
2020-10-11 21:09:49.307 Detail, Node003, Refreshed Value: old value=false, new value=false, type=bool
2020-10-11 21:09:49.307 Detail, Node003, Changes to this value are not verified
2020-10-11 21:09:49.307 Info, Node003, Received Meter report from node 3: Energy=0.000kWh
2020-10-11 21:09:49.307 Detail, Node003, Refreshed Value: old value=0.000, new value=0.000, type=decimal
2020-10-11 21:09:49.308 Info, Node003, Previous value was 0.000kWh, received 20 seconds ago.
2020-10-11 21:09:49.308 Detail, Node003, Refreshed Value: old value=0.000, new value=0.000, type=decimal
2020-10-11 21:09:49.308 Detail, Node003, Changes to this value are not verified
2020-10-11 21:09:49.308 Detail, Node003, Refreshed Value: old value=20, new value=20, type=int
2020-10-11 21:09:49.308 Detail, Node003, Notification: ValueChanged
2020-10-11 21:09:49.318 Detail, Node003, Notification: ValueChanged
2020-10-11 21:09:49.328 Detail, Node003, Notification: ValueChanged
2020-10-11 21:09:49.337 Detail, Node003, Notification: ValueChanged
Here you go.
