Aeotec zwave gen5 neo coolcam powerplug
Hi all,
I have installed the above named zwave stick and in HA I installed zwave2mqtt. If I open the software it sees the stick. So that is oke. Then I try to add the powerplug by putting the software in conclusion mode and click the button on the stick. Then qlick 3 times fast on the powerplug to connect it to the stick. But I can’t get it to work.
Please can someone tell me how to solve this?
Ensure no load is connected to the plug when performing the inclusion. The clicking has to be 3 times within 1,5 second, during which it should not turn on/off or you’re too slow. Can you provide logging? Is this the first device or are others working fine? You might have to perform exclusion first before pairing it with your Z-Stick. What hardware are you using?
I am using HA in a vm on my qnap nas. All is working fine. I have a conbee 2 stick and the zwave stick. In the conbee stick I was able to add devices. The zwave stick is alive and is seen in the zwave 2mqtt app. I have tried the add node button in the app and tried the aeotec way with the button on the stick. After licking the button 3 times within 1.5 seconds the button gets a purple color for a view seconds. It is the first device I want to add.
As I am not home now I can’t send you a logfile at the moment.
Here is the logfile. Can anyone tell me what I have to do to get it to work with adding devices.
[s6-init] making user provided files available at /var/run/s6/etc…exited 0.
[s6-init] ensuring user provided files have correct perms…exited 0.
[fix-attrs.d] applying ownership & permissions fixes…
[fix-attrs.d] done.
[cont-init.d] executing container initialization scripts…
[cont-init.d] 00-banner.sh: executing…
Add-on: Z-Wave JS to MQTT
Fully configurable Z-Wave JS to MQTT gateway and control panel; based on Zwavejs2Mqtt
Add-on version: 0.35.2
You are running the latest version of this add-on.
System: Home Assistant OS 7.4 (amd64 / qemux86-64)
Home Assistant Core: 2022.3.1
Home Assistant Supervisor: 2022.01.1
Please, share the above information when looking for help
or support in, e.g., GitHub, forums or the Discord chat.
[cont-init.d] 00-banner.sh: exited 0.
[cont-init.d] 01-log-level.sh: executing…
[cont-init.d] 01-log-level.sh: exited 0.
[cont-init.d] configuration.sh: executing…
[cont-init.d] configuration.sh: exited 0.
[cont-init.d] nginx.sh: executing…
[cont-init.d] nginx.sh: exited 0.
[cont-init.d] done.
[services.d] starting services
[services.d] done.
[19:38:44] INFO: Starting the Z-Wave JS to MQTT…
/bin/sh: git: not found
2022-03-04 19:38:50.475 INFO APP: Version: 6.5.2
2022-03-04 19:38:50.488 INFO APP: Application path:/opt
|___ / () |__ \ | | | |
____ ___ _____ _ ___ ) |_ __ ___ __ | || |_
/ /\ \ /\ / / \ \ / / _ \ / __| / /| '_ _ \ / ` | __| |
\ V V / (
| |\ V / _/ _ / /
| | | | | | (| | || |_
/|_/_/ _,| _/ _| |/|| || ||_, |_|_|
|__/ |
2022-03-04 19:38:50.653 WARN STORE: scenes.json not found
2022-03-04 19:38:50.789 INFO APP: Listening on port 44920 host 0.0.0.0 protocol HTTP
2022-03-04 19:38:50.908 INFO MQTT: MQTT is disabled
2022-03-04 19:38:50.961 INFO ZWAVE: Connecting to /dev/ttyACM1
2022-03-04T18:38:50.968Z DRIVER ███████╗ ██╗ ██╗ █████╗ ██╗ ██╗ ███████╗ ██╗ ███████╗
2022-03-04T18:38:50.973Z DRIVER version 8.11.6
2022-03-04T18:38:50.976Z DRIVER
[19:38:51] INFO: Starting NGinx…
Most likely it could be USB3 incompatibility or interference, so an extension cord for USB should be tried. Otherwise you’d need to gather the Zwave logging instead of the addon startup logs.
Finally found the solution.
I have to reset every plug before it is seen by the zwave stick.
Thanks for helping.
