I cannot for the life of me get the Z Stick recognized. Shows opens port but no response. Any ideas
2017-12-28 11:37:47.202 Always, OpenZwave Version 1.4.2586 Starting Up
2017-12-28 11:37:49.712 Info, Setting Up Provided Network Key for Secure Communications
2017-12-28 11:37:49.712 Warning, Failed - Network Key Not Set
2017-12-28 11:37:49.712 Info, mgr, Added driver for controller /dev/ttyAMA0
2017-12-28 11:37:49.712 Info, Opening controller /dev/ttyAMA0
2017-12-28 11:37:49.712 Info, Trying to open serial port /dev/ttyAMA0 (attempt 1)
2017-12-28 11:37:49.713 Info, Serial port /dev/ttyAMA0 opened (attempt 1)
2017-12-28 11:37:49.713 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_GET_VERSION: 0x01, 0x03, 0x00, 0x15, 0xe9
2017-12-28 11:37:49.713 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_MEMORY_GET_ID: 0x01, 0x03, 0x00, 0x20, 0xdc
2017-12-28 11:37:49.713 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_GET_CONTROLLER_CAPABILITIES: 0x01, 0x03, 0x00, 0x05, 0xf9
2017-12-28 11:37:49.713 Detail, contrlr, Queuing (Command) FUNC_ID_SERIAL_API_GET_CAPABILITIES: 0x01, 0x03, 0x00, 0x07, 0xfb
2017-12-28 11:37:49.713 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_GET_SUC_NODE_ID: 0x01, 0x03, 0x00, 0x56, 0xaa
2017-12-28 11:37:49.714 Detail,
2017-12-28 11:37:49.714 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x15) - FUNC_ID_ZW_GET_VERSION: 0x01, 0x03, 0x00, 0x15, 0xe9
2017-12-28 11:37:50.714 Error, contrlr, ERROR: Dropping command, expected response not received after 1 attempt(s)
2017-12-28 11:37:50.714 Detail, contrlr, Removing current message
2017-12-28 11:37:50.714 Detail, contrlr, Notification: Notification - TimeOut
2017-12-28 11:37:50.716 Detail,
2017-12-28 11:37:50.716 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x20) - FUNC_ID_ZW_MEMORY_GET_ID: 0x01, 0x03, 0x00, 0x20, 0xdc
2017-12-28 11:37:51.716 Error, contrlr, ERROR: Dropping command, expected response not received after 1 attempt(s)
2017-12-28 11:37:51.716 Detail, contrlr, Removing current message
2017-12-28 11:37:51.716 Detail, contrlr, Notification: Notification - TimeOut
2017-12-28 11:37:51.718 Detail,
2017-12-28 11:37:51.718 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x05) - FUNC_ID_ZW_GET_CONTROLLER_CAPABILITIES: 0x01, 0x03, 0x00, 0x05, 0xf9
2017-12-28 11:37:52.718 Error, contrlr, ERROR: Dropping command, expected response not received after 1 attempt(s)
2017-12-28 11:37:52.718 Detail, contrlr, Removing current message
2017-12-28 11:37:52.718 Detail, contrlr, Notification: Notification - TimeOut
2017-12-28 11:37:52.730 Detail,
2017-12-28 11:37:52.730 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x07) - FUNC_ID_SERIAL_API_GET_CAPABILITIES: 0x01, 0x03, 0x00, 0x07, 0xfb
2017-12-28 11:37:53.731 Error, contrlr, ERROR: Dropping command, expected response not received after 1 attempt(s)
2017-12-28 11:37:53.731 Detail, contrlr, Removing current message
2017-12-28 11:37:53.731 Detail, contrlr, Notification: Notification - TimeOut
2017-12-28 11:37:53.734 Detail,
2017-12-28 11:37:53.734 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x56) - FUNC_ID_ZW_GET_SUC_NODE_ID: 0x01, 0x03, 0x00, 0x56, 0xaa
2017-12-28 11:37:54.734 Error, contrlr, ERROR: Dropping command, expected response not received after 1 attempt(s)
2017-12-28 11:37:54.734 Detail, contrlr, Removing current message
2017-12-28 11:37:54.734 Detail, contrlr, Notification: Notification - TimeOut
2017-12-28 11:49:01.907 Error, mgr, Manager::GetDriver failed - Home ID 0x00000000 is unknown
2017-12-28 11:49:01.908 Warning, Exception: Manager.cpp:373 - 100 - Invalid HomeId passed to GetDriver
2017-12-28 11:49:01.908 Info, mgr, Manager::WriteConfig failed - _homeId 0 not found
2017-12-28 11:49:02.911 Detail, Notification: DriverRemoved
2017-12-28 11:49:02.911 Always, ***************************************************************************
2017-12-28 11:49:02.912 Always, ********************* Cumulative Network Statistics *********************
2017-12-28 11:49:02.912 Always, *** General
2017-12-28 11:49:02.912 Always, Driver run time: . . . 0 days, 0 hours, 11 minutes
2017-12-28 11:49:02.912 Always, Frames processed: . . . . . . . . . . . . . . . . . . . . 0
2017-12-28 11:49:02.912 Always, Total messages successfully received: . . . . . . . . . . 0
2017-12-28 11:49:02.912 Always, Total Messages successfully sent: . . . . . . . . . . . . 5
2017-12-28 11:49:02.912 Always, ACKs received from controller: . . . . . . . . . . . . . 0
2017-12-28 11:49:02.912 Always, *** Errors
2017-12-28 11:49:02.912 Always, Unsolicited messages received while waiting for ACK: . . 0
2017-12-28 11:49:02.912 Always, Reads aborted due to timeouts: . . . . . . . . . . . . . 0
2017-12-28 11:49:02.912 Always, Bad checksum errors: . . . . . . . . . . . . . . . . . . 0
2017-12-28 11:49:02.912 Always, CANs received from controller: . . . . . . . . . . . . . 0
2017-12-28 11:49:02.912 Always, NAKs received from controller: . . . . . . . . . . . . . 0
2017-12-28 11:49:02.913 Always, Out of frame data flow errors: . . . . . . . . . . . . . 0
2017-12-28 11:49:02.913 Always, Messages retransmitted: . . . . . . . . . . . . . . . . . 0
2017-12-28 11:49:02.913 Always, Messages dropped and not delivered: . . . . . . . . . . . 5
2017-12-28 11:49:02.913 Always, ***************************************************************************
2017-12-28 11:49:02.913 Warning, WARNING: Tried to write driver config with no home ID set
2017-12-28 11:49:04.914 Info, mgr, Driver for controller /dev/ttyAMA0 removed
2017-12-28 11:49:17.946 Info, Setting Up Provided Network Key for Secure Communications
2017-12-28 11:49:17.946 Warning, Failed - Network Key Not Set
2017-12-28 11:49:17.946 Info, mgr, Added driver for controller /dev/ttyAMA0
2017-12-28 11:49:17.946 Info, Opening controller /dev/ttyAMA0
2017-12-28 11:49:17.947 Info, Trying to open serial port /dev/ttyAMA0 (attempt 1)
2017-12-28 11:49:17.947 Info, Serial port /dev/ttyAMA0 opened (attempt 1)
2017-12-28 11:49:17.948 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_GET_VERSION: 0x01, 0x03, 0x00, 0x15, 0xe9
2017-12-28 11:49:17.948 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_MEMORY_GET_ID: 0x01, 0x03, 0x00, 0x20, 0xdc
2017-12-28 11:49:17.948 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_GET_CONTROLLER_CAPABILITIES: 0x01, 0x03, 0x00, 0x05, 0xf9
2017-12-28 11:49:17.948 Detail, contrlr, Queuing (Command) FUNC_ID_SERIAL_API_GET_CAPABILITIES: 0x01, 0x03, 0x00, 0x07, 0xfb
2017-12-28 11:49:17.948 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_GET_SUC_NODE_ID: 0x01, 0x03, 0x00, 0x56, 0xaa
2017-12-28 11:49:17.948 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x15) - FUNC_ID_ZW_GET_VERSION: 0x01, 0x03, 0x00, 0x15, 0xe9
2017-12-28 11:49:18.949 Error, contrlr, ERROR: Dropping command, expected response not received after 1 attempt(s)
2017-12-28 11:49:18.949 Detail, contrlr, Removing current message
2017-12-28 11:49:18.949 Detail, contrlr, Notification: Notification - TimeOut
2017-12-28 11:49:18.949 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x20) - FUNC_ID_ZW_MEMORY_GET_ID: 0x01, 0x03, 0x00, 0x20, 0xdc
2017-12-28 11:49:19.950 Error, contrlr, ERROR: Dropping command, expected response not received after 1 attempt(s)
2017-12-28 11:49:19.950 Detail, contrlr, Removing current message
2017-12-28 11:49:19.950 Detail, contrlr, Notification: Notification - TimeOut
2017-12-28 11:49:19.954 Detail,
2017-12-28 11:49:19.954 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x05) - FUNC_ID_ZW_GET_CONTROLLER_CAPABILITIES: 0x01, 0x03, 0x00, 0x05, 0xf9
2017-12-28 11:49:20.954 Error, contrlr, ERROR: Dropping command, expected response not received after 1 attempt(s)
2017-12-28 11:49:20.955 Detail, contrlr, Removing current message
2017-12-28 11:49:20.955 Detail, contrlr, Notification: Notification - TimeOut
2017-12-28 11:49:20.960 Detail,
2017-12-28 11:49:20.960 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x07) - FUNC_ID_SERIAL_API_GET_CAPABILITIES: 0x01, 0x03, 0x00, 0x07, 0xfb
2017-12-28 11:49:21.961 Error, contrlr, ERROR: Dropping command, expected response not received after 1 attempt(s)
2017-12-28 11:49:21.961 Detail, contrlr, Removing current message
2017-12-28 11:49:21.961 Detail, contrlr, Notification: Notification - TimeOut
2017-12-28 11:49:21.962 Detail,
2017-12-28 11:49:21.962 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x56) - FUNC_ID_ZW_GET_SUC_NODE_ID: 0x01, 0x03, 0x00, 0x56, 0xaa
2017-12-28 11:49:22.962 Error, contrlr, ERROR: Dropping command, expected response not received after 1 attempt(s)
2017-12-28 11:49:22.962 Detail, contrlr, Removing current message
2017-12-28 11:49:22.962 Detail, contrlr, Notification: Notification - TimeOut
