Aeris Aair
Hi everyone,
I bought Aeris Aair air purifier it seems it doesn’t have integration with home assistant. It has a WiFi connection and an app. It can connect to with Alexa however I couldn’t test that as I do t know any of the amazons speakers.
Was anyone able to connect it with home assistant? Maybe there is a hack to do it?
I appreciate your help.
Here is the link to the product
https://aeris.irobot.de/en-DE/product/aair-3-in-1-pro
The manufacturers homepage is not really that informative, so I assume they do not have an API, and that means the app and device is probably directly connecting to the manufacturers cloud servers with an encrypted connection.
This means there is probably no way to control it in other ways than what the manufacturer have decided to provide.
The Alexa skill might be a workaround, but I have no idea how to set that up, because I avoid those cloud services.
I have an idea Marek,
For you and anyone else that’s a Aeris Aair Customer, I would suggest asking the mfgr to look into the works with home assistant program to see if their API would be compatible with HA.
Introducing the Works with Home Assistant program - Home Assistant.
The more of their customers that request this, the more likely it would happen.
The other way is to get someone to write something which 99% of the time is someone with the hardware or a desire to use the software and has the chops to write a custom Integration. If someone so chooses this can also be a core integration but that takes more work and commitment, There are thousands of core integrations, so it happens, but there are probably more custom ones than that because the entry bar is lower.
@Flagun did you manage to find an integration or make any progress with this?
None, it even seems that they turned off their servers and the app doesn’t work.
Thanks, appreciate the follow-up. I don’t have my Aeris account details anymore and I am reluctant to sign up again, since they want too much personal information.
Since yesterday the app works again. They finaly discovered the cleaning lady unplugged the server for the hoover.
Hi there, today I looked at the hardware of the purifier and it looks like it could be quite easily flashed with other firmware that could allow local of the device without connection to the cloud.
If anyone is interested of how the device looks inside there is my gist: Aeris Aair 3-in-1 Pro Air Purifier Hardware · GitHub
Just checking in to see if anyone had any further thoughts or information about connecting the Aeris Aair to Home Assistant.
So far, I’ve been using a workaround, which is a smart-plug. I have a HA automation to toggle the machine depending on the PM2.5 count.
I have published an alternative firmware that gets the purifier into Home Assistant here
