Looks like the “Automatic Reporting Interval” happens every 12 hours. Because this is a temperature sensor I would like this to report more often as some other automation will kick in based on those values.
How can I do that? I keep changing the values but they continue going back to default.
Directly after you change it, you need to wake up the device, so it will receive the message. Not doing so, the message will be dropped after some unsuccessful attempts.
So change the value, it will be placed in a queue, walk to the sensor and press it’s button once.
