The ~$20 Heiman Zigbee Siren, according to users, doesn’t have volume control via Home Assistant.
The Aeotec Siren 6 is $80 for what is essentially just a speaker.
I’m not really seeing any other options so was hoping I could get some recommendations - what do you use for an alarm system siren? Can it be configured to work for other noises, etc?
Mine’s a Moes, but it also cost about £20.00. The only UI control it has is an on/off switch, but I use an automation to select the siren sound (I also use it as a doorbell) and set the volume to high.
alias: Alarm triggered
description: >-
Sets siren melody to 11, alarm duration to 30 sec and volume to high, then
sounds alarm.
mode: single
triggers:
- entity_id:
- alarm_control_panel.alarmo
to: triggered
alias: Alarmo changes to triggered
trigger: state
conditions: []
actions:
- target:
entity_id: switch.kitchen_siren_switch
data: {}
alias: Turn off kitchen siren
action: switch.turn_off
- data:
cluster_type: in
ieee: a4:c1:38:f1:70:6e:2a:cc
endpoint_id: 1
cluster_id: 6
attribute: 1126
value: NeoAlarmMelody.melody_11
alias: Set siren sound to alarm
action: zha.set_zigbee_cluster_attribute
- data:
cluster_type: in
endpoint_id: 1
cluster_id: 6
attribute: 615
value: "30"
alias: Set duration to 30 sec
- data:
cluster_type: in
endpoint_id: 1
cluster_id: 6
attribute: 1140
value: NeoAlarmVolume.high
alias: Set volume to high
- delay:
hours: 0
minutes: 0
seconds: 5
milliseconds: 0
- target:
data: {}
alias: Sound alarm
action: switch.turn_on
There’s a good review of the Heiman here, with instructions about how to set it up. It does mention that some people are having problems:
