This also doesn’t look like the Modified Zepp app, are you sure you installed the right apk? Should be “Zepp version 7.7.5-play”
I use the one you sent the google drive link of
Did you deinstall other android apps? You can’t have the original Zepp app installed at the same time. Can you show some screenshots of the app menu?
This completely slipped my mind here is the repo
Does this work with Mi Redmi Watch 4?
This is not a ZeppOS device, so probably not.
I have a Mi Band 7 NFC. Using this I need to reset the Watch to connect to the Zepp app which means I can not use Mi Pay any more right? That would be very sad.
Yes, the Zepp app is required to get an internet connection through the mobile phone for the ha-zepp app.
I see there is a Zepp Pay as well, but I am not sure if it works for the mi-band7.
Hi! This looks great!
I am not familiar with zepp apps, i just discovered how to install custom apps through watch faces and managed them with ‘toolbox’. However i imagine this has nothing to do with that.
Is there any chance that you can point me in the right way to install your app in my Xiaomi Band 7?
Thanks in advanced!
Hi! For the ha-zepp app to function properly, you need the Zepp app on your phone that handles the internet connection for the ha-zepp app, see Zepp architecture.
The mi-band7 is not officially supported for this. But there is a way to get the mi-band working with the Zepp app, follow the steps on the ha-zepp repository.
Thanks!
Once i Sync the Xiaomi band, how can i install de home Assistant app?
When you have enabled developer mode in Zepp app and build the ha-zepp source code using the command zeus preview
. You can scan the QR code in the developer mode
I triyed with the mod Zepp app (it says to me also that i need a newer version) and also generating a custom QR to look like a Amazfit Band 7 (it says this device it is not supported).
Both of them fails to pair the band. Any clue what should i do?
It should work with the official app and only the Modified QR code, are you on Android or iOS?
I am Android user. I used the official app, changed my mac address to generate de QR, but it says the device is not supported.
By the way, i triyed this two Zepp apps.
Ok, my bad! I was using a wrong mac address
Now i can get it paired with de fake QR, but as long as it is paired it switches from Amazfit band 7 to Xiaomi Band 7
Yep that’s normal. Everything should work now. The mi band 7 is not officially supported for the Zepp app, since Xiaomi want to build its own shell around it and moved to Mi fitness. The mi-band7 does run Zeppos, so the Zepp app does recognize the band after pairing as mi band 7. However, since Xiaomi does not officially support mini programs, there is an annoying bug where a green/yellow ish screen pops up after a few page refreshes.
Just to confirm, do you mean that it does not matter if the band is identified as “Xiaomi Band” as long as is paired into Zepp app?
Thanks again!!
It worked for me 2 weeks ago like this. Let me know if you can install the ha-zepp app and if everything works accordingly.
Ok, i got install zeus cli… Maybe this is too much to ask, but how do exactly build the ha-zepp source code??
