HUSZBZ-1 Stick, everything was working great until I did yesterday’s update and now all my zigbee devices are becoming unavailable after an hour or two and then come back alive instantly after restarting HA.
Nothing about our WiFi or config changed other than the update and I can’t find any issues in the logs other than “The ‘usb_path’ option is deprecated, please remove it from your configuration”
Any ideas what could be causing this issue or where I should look?
I have not had that same behavior. I have the same stick and many zigbee devices (39 total), open close, motion, lights, leak and power. I will say I’ve been tweaking a lot and have restarted HA quite a bit too, so I’ll pay closer attention, and let you know if I notice anything as well
I too have that stick and no issues. 68 devices online and working.
I have the same problem, After loosing the connection. IT is restored after a few minutes.
I am thinking to rollback to 0.112
Update:
My setup in general was getting super laggy and Lovelace wasn’t responding well in addition to dropping my zigbee devices. My database on the SD card was constantly writing to a 900MB+ file so before rolling back I decided to move my database over to my Synology using MariaDB. Since making the database move everything has been working better than before and no more device dropouts since.
Update:
I restored the back-up version 0.113, but still dropping ZHA and restored after a minute.
Then I shutdown the system complete. Turned of the power, waited 1-2 minutes and started up again.
The response of Home Assistant was faster then before.
I had 1 drop of the ZHA, but it came back and no problem seen anymore.
I upgraded to 0.113.1 and added 6 new Zigbee devices.
So no problem for me anymore. ![:slight_smile: :slight_smile:](https://community.home-assistant.io/images/emoji/twitter/slight_smile.png?v=9)
