After 10pm before sunrise automation
I have an automation I’m trying to set to only occur between 10pm and sunrise. It seems to work in the evening (I’m guessing between 10pm and midnight?) but not in the early AM before sunrise. I’m guessing the issue is that it doesn’t consider 5am to be “after” 10pm? How would you fix this without two separate automations (one for 10p-midnight and another for midnight-sunrise)?
Hard to see but you seem to have sunrise and sunset checked. Is that right?
Use sun - below Horizon as the condition. Before and after sunset in a condition does not work, as it stops at midnight like you thought.
Hard to tell what is going on here. Is this a trigger you are attempting to set up, or a set of conditions to restrict some other trigger? Post the entire code rather than a cropped screenshot.
Ok, will give that a shot, thanks.
