Another one failing. Bloody hell
Logger: homeassistant.core
Source: core.py:2814
First occurred: 18:35:14 (4 occurrences)
Last logged: 21:30:19
Error executing service: <ServiceCall switch.turn_off (c:01JPDHD211AHTG6EGE2QNR7N0P): entity_id=['switch.np19_pflanzen']>
Error executing service: <ServiceCall switch.turn_off (c:01JPDHDQXGPBDKRZPT4K6A8XN6): entity_id=['switch.np19_pflanzen']>
Error executing service: <ServiceCall switch.turn_off (c:01JPDHP701CAJFGN545P2J2KJM): entity_id=['switch.np19_pflanzen']>
Error executing service: <ServiceCall switch.turn_on (c:01JPDVDFY25WBZ76S58YJGMNCW): entity_id=['switch.np20_bad']>
File "/usr/local/lib/python3.13/site-packages/zha/zigbee/cluster_handlers/__init__.py", line 68, in wrap_zigpy_exceptions
yield
File "/usr/local/lib/python3.13/site-packages/zha/zigbee/cluster_handlers/__init__.py", line 86, in wrapper
return await RETRYABLE_REQUEST_DECORATOR(func)(*args, **kwargs)
File "/usr/local/lib/python3.13/site-packages/zigpy/util.py", line 136, in retry
return await func()
File "/usr/local/lib/python3.13/site-packages/zigpy/quirks/__init__.py", line 263, in command
return await self.request(
...<8 lines>...
File "/usr/local/lib/python3.13/site-packages/zigpy/zcl/__init__.py", line 378, in request
return await self._endpoint.request(
...<9 lines>...
File "/usr/local/lib/python3.13/site-packages/zigpy/endpoint.py", line 270, in request
return await self.device.request(
...<11 lines>...
File "/usr/local/lib/python3.13/site-packages/zigpy/device.py", line 378, in request
await send_request()
File "/usr/local/lib/python3.13/site-packages/zigpy/application.py", line 835, in request
await self.send_packet(
...<14 lines>...
File "/usr/local/lib/python3.13/site-packages/bellows/zigbee/application.py", line 937, in send_packet
raise zigpy.exceptions.DeliveryError(
f"Failed to deliver message: {send_status!r}", send_status
zigpy.exceptions.DeliveryError: Failed to deliver message: <sl_Status.ZIGBEE_DELIVERY_FAILED: 3074>
File "/usr/src/homeassistant/homeassistant/components/zha/helpers.py", line 1352, in handler
return await func(self, *args, **kwargs)
File "/usr/src/homeassistant/homeassistant/components/zha/switch.py", line 63, in async_turn_off
await self.entity_data.entity.async_turn_off()
File "/usr/local/lib/python3.13/site-packages/zha/application/platforms/switch.py", line 100, in async_turn_off
await self._on_off_cluster_handler.turn_off()
File "/usr/local/lib/python3.13/site-packages/zha/zigbee/cluster_handlers/general.py", line 472, in turn_off
result = await self.off()
File "/usr/local/lib/python3.13/site-packages/zha/zigbee/cluster_handlers/__init__.py", line 85, in wrapper
with wrap_zigpy_exceptions():
File "/usr/local/lib/python3.13/contextlib.py", line 162, in __exit__
self.gen.throw(value)
File "/usr/local/lib/python3.13/site-packages/zha/zigbee/cluster_handlers/__init__.py", line 77, in wrap_zigpy_exceptions
raise ZHAException(message) from exc
zha.exceptions.ZHAException: Failed to send request: Failed to deliver message: <sl_Status.ZIGBEE_DELIVERY_FAILED: 3074>
File "/usr/src/homeassistant/homeassistant/core.py", line 2814, in _run_service_call_catch_exceptions
await coro_or_task
File "/usr/src/homeassistant/homeassistant/core.py", line 2837, in _execute_service
return await target(service_call)
File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 1007, in entity_service_call
single_response = await _handle_entity_call(
hass, entity, func, data, call.context
File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 1079, in _handle_entity_call
result = await task
File "/usr/src/homeassistant/homeassistant/components/zha/helpers.py", line 1354, in handler
raise HomeAssistantError(err) from err
homeassistant.exceptions.HomeAssistantError: Failed to send request: Failed to deliver message: <sl_Status.ZIGBEE_DELIVERY_FAILED: 3074>
Logger: homeassistant.components.automation.susi_heizung_an
Source: components/automation/__init__.py:738
integration: Automation (documentation, issues)
First occurred: 20:50:18 (7 occurrences)
Last logged: 21:20:27
Error while executing automation automation.susi_heizung_an: Failed to send request: Failed to deliver message: <sl_Status.ZIGBEE_DELIVERY_FAILED: 3074>
