i’m using HASS OS as OVA on a Virtual Machine on my Synology. It worked for a few years without issues. Lately it started to have some very strange issue. It could be connected to the latest supervisor update, but i’m not 100% sure.
What it does:
After Restart (OS or Core) everything works perfectly
Some time later (probably 30 minutes) the problems begin
Addons are not accessible via ingress anymore: trying to access them gives a timeout or Unable to load the panel source: /api/hassio/app/entrypoint.js.
Addons itself are running (i see it for example for fully working Zigbee2MQTT addon in MQTT)
Trying to access Settings => Addons gives “Could not load the Supervisor panel!”
Restarting from the interface doesn’t work anymore
The observer-statuspage gives
Home Assistant observer
Supervisor:
Connected
Supported:
Supported
Healthy:
Healthy
Restarting / Reparing the observer doesn’t help
Restarting HA Core via CLI fixes the issue temporarly again.
Does anyone has an advice what i could try next? What logger should i increase / have a look to?
I have the exact same issues here.
I am running HAOS on a VM (Virtual Box).
Restart fix the issue but only temporarily.
On logs the only thing that gives error on SU is this
23-01-06 20:46:34 ERROR (MainThread) [asyncio] Task exception was never retrieved
future: <Task finished name='Task-2526' coro=<Addon.watchdog_container() done, defined at /usr/src/supervisor/supervisor/addons/addon.py:988> exception=AddonsJobError('Rate limit exceeded, more then 10 calls in 0:30:00')>
