After changing configuration.yaml system restore old file
I’m frustraded by now and decide to ask community.
I’m returning to homeassistant after a while, and now i’m facing quite anoying problem.
After logging into my virtual enviorment for my user dedicated for homeassistant
(BTW: i was fallowing this guide)
I wnated to try Spotify in Home-Assistant in my webpage. (I’m running v0.49)
After changing something in my configuration.yaml:
a. i cannot restart homeassistant by itself from the webpage
b. After reboot the raspberry pi the file which was changed successfully (i double chcked it) returns to form from 2 months ago. Live egzample: today is 08.10.2017 and had propper date and time. After reboot file restore content from 24.07.2017.
Please help me if You can!!!
I really do not want to restoring all system again :frowning:
Is this raspberry pi? (Bad sdcard…maybe try another…)
It is Raspberry Pi 3.
Yeah, i will check it but before reboot everything is stored properly.
I even upload the photo into this SD to be sure.
When my SD cards went bad I had similar symptom…delete file but file return at reboot or change file but file unchanged after reboot.
@tmjpugh i hope to find time today to set up everything from scratch and then i will definitely know if SD card is the problem.
I will be very sad if SD card will be the problem finally because it is really good card. 16 GB SanDisk Class 10. I bought it a year ago.
@tmjpugh hello again,
I did a test. I create a file outside of virtual environment where Home assistant is sitting, and than reboot machine.
File disappear :frowning: so i thing the SD is really the problem.
